VTEC Engage
VTEC Engage
Wassup Hondatech, So i'm having a bit of a issue here, a friend of mine has done a engine swap onto my car putting a JDM B16A2 in, The problem that i am having though is the car is not engaging VTEC at all not even at 5,500 RPM I tried going a bit higher around 7 7.5 but no sign of it.
Was wondering if anyone has had this issue before and what the main causes would be.
Also that my car aswell is Misfiring when it drives but fine in idle!
Any information regarding this would help alot thankyou!
Re: VTEC Engage
Re: VTEC Engage
I'm having a code 3 for Map sensor and i dont have one on, and apparently my mate was sayign that JDM B16A2s dont have one.. and im using a aftermarket ECU that is also apparently a spoon ecu
Re: VTEC Engage
With friends like that....
The ECU uses a Pressure-Density fuel mixture control scheme. A MAP sensor is essential to this scheme.
If it is a chipped ECU you need to look at the documentation for the chip and the tune.
Re: VTEC Engage
Yeah man He fucked me over big time, apologies for the language if it isnt allowed here, Did you have snapchat, cause i can snapchat you videos of whats happening with my car being a bit more descriptive
Thanks heaps !
Thanks heaps !
Re: VTEC Engage
Put a map sensor in. It needs one to read air/fuel mixture.
Just because its a spoon ecu, it doesnt make it the best setup for your motor. Get one that’ll work for a jdm b16 so you can drive to your tuner and Get it tuned to your exact setup.
Re: VTEC Engage
you should never allow them near your car again. Clearly have no idea how to work on honda. And earlier B16a’s have a firewall mounted map sensor. Taht may be where rhe confusion is coming from.
Re: VTEC Engage
Looks like a USDM B16A2 engine, but the intake manifold must be from a JDM B16A SIR-II which takes the remote MAP sensor. The vacuum port coming off the top of the throttle body should connect to it.
Re: VTEC Engage
The rubber hose coming off the TB sitting on the intake tube MUST be connected to a map sensor, you will have to find a way to mount it or find the fuel filter/map sensor bracket (they go together) i can post a pic of mine if you need, or u can zip tie a map to something to secure. Second, i would remove the red cap on the black tube and put a little filter on it since it can’t reach the intake tube, this part is designed to draw fresh air into the engine.
Re: VTEC Engage
Red1995egcoupe
13
06-14-2019 04:26 PM
JDMlyfestyle
11-13-2003 01:59 PM
