Bottom end bearing scratched
Old Mar 27, 2019 | 04:26 PM
pacurcouch's Avatar
Default Bottom end bearing scratched
Hey i just got my D16A back from the machine shop, is this bad if its scratched, where the bearings and crankshaft sit? Can i still use it.
1st scratch, one long one
Middle one
Old Mar 27, 2019 | 08:06 PM
motoxxxman's Avatar
Default Re: Bottom end bearing scratched
you said you picked the block up from the machine shop like that?
Was it like that before you dropped it off?
Makes me wonder if the machine shop switched your block with someone else's. That happens more often than you might think.
To answer your question, it might be useable. But I definitely wouldn't use it in my car.
Old Mar 27, 2019 | 10:19 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Based on the pics that you have posted... I would say that block is junk. Scrap money.
Old Mar 30, 2019 | 02:52 AM
pacurcouch's Avatar
what happens if i use it? It will spin a bearing?
Old Mar 30, 2019 | 04:37 AM
motoxxxman's Avatar
It can put uneven pressure on different parts of the bearing, which warps the bearing and causes drastically uneven wear spots. Which also overheats the bearing, and can cause it to collapse, and then finally yes spin the bearing.
Old Mar 30, 2019 | 06:01 AM
D21X's Avatar
Yup block is junk. Pic of middle one, looks like it got compressed towards the left side, no good.
I would go back to the machine shop and tell them they screwed up.
Old Mar 30, 2019 | 04:59 PM
motoxxxman's Avatar
^this?
Turbo_TONY
Jan 31, 2009 11:32 AM
neil-ste
Jan 26, 2008 03:29 PM
turbotime
Mar 24, 2006 05:33 PM
BoOsTiN Dc2
Mar 15, 2004 06:47 PM
redman223
Jan 2, 2004 06:53 PM
