1992 accord 3k rev limit.
Old Mar 7, 2019 | 09:48 PM
Rusty Flores's Avatar
Default 1992 accord 3k rev limit.
Hi so today i took my battery out of my car to let my friend use it to start his car and check some things and was put back into my car within about 10 min. Went and turned my car on and the check emgine light has come on and i have a rev limit of 3k in every gear.
Old Mar 7, 2019 | 11:23 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: 1992 accord 3k rev limit.
Find two wire blue connector above the passenger kick panel.
Jumper connector with wire.
Turn ignition to II(ON).
Observe warning lights for codes via blinking.
Record codes and report back.
Old Mar 7, 2019 | 11:47 PM
what do you mean by jumper connecter with wire?
Old Mar 8, 2019 | 09:50 AM
MAD_MIKE's Avatar
MM Gruppe B
Find a conductive piece of wire, be it an uncoated paperclip, single strand of telephone wire, or the girlfriends uncoated bobby pin.
Jumper the two wire blue connector with said wire to complete circuit.
Turn ignition to II(ON) and watch for the warning lamps to start blinking if they have a stored code.
Old Mar 10, 2019 | 03:44 PM
ok so i did all the ecu resets i could find and the check engine light never goes off even after removing battery cables and fuse. And when doing the code read i got 0 flash on my check engine and 1 flash on my abs. Still stuck in limp mode i know im due for an oil change but im not low coild that be it.
Old Mar 12, 2019 | 02:42 PM
MAD_MIKE's Avatar
MM Gruppe B
If you cleared the codes before checking for codes, your not going to have any codes.
I would suggest disconnecting the battery again, verify that you disconnected/reconnected the battery correctly.
Negative cable is removed first, then Positive.
Postive installed first, then Negative.
Verify the cables are in good condition,
Verify the battery is fully charged.
Verify there are no modifications done to the wire harness, alarms, sound system that may have been wired incorrectly.
Old Mar 15, 2019 | 06:09 AM
i disconnected the battery as you intstructed the check emgine light came on immediately once i started the car again still in limp mode. I am missing the correct size wrench to take the plate off over the ecu.
ekhatchey
Audio / Security / Video
Nov 5, 2010 12:21 PM
AFTricker
Jan 1, 2010 05:17 PM
onefastjew
Jul 14, 2007 05:18 PM
flip1199
Jul 29, 2005 02:48 PM
yoshio006
May 22, 2005 06:49 PM
