1992 accord 3k rev limit.
Hi so today i took my battery out of my car to let my friend use it to start his car and check some things and was put back into my car within about 10 min. Went and turned my car on and the check emgine light has come on and i have a rev limit of 3k in every gear.
MM Gruppe B
Re: 1992 accord 3k rev limit.
MM Gruppe B
Find a conductive piece of wire, be it an uncoated paperclip, single strand of telephone wire, or the girlfriends uncoated bobby pin.
Jumper the two wire blue connector with said wire to complete circuit.
Turn ignition to II(ON) and watch for the warning lamps to start blinking if they have a stored code.
MM Gruppe B
ok so i did all the ecu resets i could find and the check engine light never goes off even after removing battery cables and fuse. And when doing the code read i got 0 flash on my check engine and 1 flash on my abs. Still stuck in limp mode i know im due for an oil change but im not low coild that be it.
I would suggest disconnecting the battery again, verify that you disconnected/reconnected the battery correctly.
Negative cable is removed first, then Positive.
Postive installed first, then Negative.
Verify the cables are in good condition,
Verify the battery is fully charged.
Verify there are no modifications done to the wire harness, alarms, sound system that may have been wired incorrectly.
If you cleared the codes before checking for codes, your not going to have any codes.
