97 Honda civic ex Charging issues
Old Feb 16, 2019 | 01:37 AM
akremer01's Avatar
Default 97 Honda civic ex Charging issues
Whatsup everybody?!
I've got a 97 honda civic ex. I'm in Minnesota so it's a little chilly right now. I installed a new battery yesterday, before that I had a almost 4 year old battery that didn't have the cca needed for the -50 degree wind chill we had a few weeks ago. On that cold day I had to much faith in it and I killed it trying to start. Got a jump on it and eventually it started. 3 days ago I was driving home, the engine was fully warmed so I turned on the defroster and it seemed like there was a drop in electric power. I noticed the battery light on my dash was on, went on and off a few times then just stayed on. Tested the battery when I 1st saw the light and it was around 12.6. It must of been around this time I wasn't getting any charge back in the battery. Drove around 7 miles to work. Tested and found slightly lower voltage. Got a jump start at work because I new the battery was weak and about 2-3 miles down the road it died on me. Cleaned the battery connectors and terminals and installed a new battery. Battery dash light still on. pushed in and wiggled plug to alternator, checked connections and wiring, nothing obvious. Checked fuse 15, its good. Are there common places where wiring can be an issue on this model? My guess is it's either the Electrical Load Detector (which I have yet to find replacement) or the Alternator. Anybody know what I should do? Thanks
Old Feb 16, 2019 | 05:31 AM
mk378's Avatar
Default Re: 97 Honda civic ex Charging issues
Check that the alternator belt is tight and the alternator actually spins when the engine is running.
Most likely this problem is the alternator itself, though the wires involved in the fuse 15 problem can cause trouble without the fuse blowing.
Old Feb 16, 2019 | 05:10 PM
akremer01's Avatar
It's tight and spinning. I'll inspect and test the wiring involved in fuse 15. Just to rule it out since I've already pulled out the ELD, do you know how to test it? Thanks
Old Feb 16, 2019 | 06:42 PM
mk378's Avatar
The ELD would not cause this. The battery light is driven by a self-check circuit inside the alternator. Battery light on results from:
Alternator shaft not turning.
Faulty alternator.
Shorted wiring.
Old Feb 16, 2019 | 07:45 PM
akremer01's Avatar
Ok. I'll put the ELD back, check the wiring, and if everything checks out I'll be removing the alternator. Hey, thanks alot!!!
Old Feb 18, 2019 | 02:02 AM
akremer01's Avatar
I tested the alternator plug to the negative battery wire and all had continuity accept the white with green stripe. Tested wht-grn from alternator plug end to computer plug end and it had continuity. However, the computer is rusted and corroded on the bottom left corner. I opened it up and took a look but as as far as the circuit board goes it looked good. Also I did a diode test on the alternator and it passed. Anybody know the next step in this troubleshoot?
Old Feb 18, 2019 | 11:55 AM
akremer01's Avatar
Is the wht/grn wire supposed to have continuity from the alternator plug to the battery negative wire?
Old Feb 18, 2019 | 08:16 PM
akremer01's Avatar
Reinstalled the ecu and did a full field test on the alternator, it failed. Opened it up and so far it looks like the capacitor in it is whats faulty. I'm gonna give it some charge and test it. Hopefully my new alternator arrives soon.
Old Feb 22, 2019 | 01:32 AM
akremer01's Avatar
Put the new alternator in the other day and its been running great.
Mr. Mark
Mar 6, 2018 05:52 PM
NoOneFromNoWher
Honda Civic (2001 - 2005)
Sep 3, 2014 06:10 AM
Drew916
Jun 22, 2012 09:25 AM
Outlaw-Hondaz
28
Nov 19, 2010 03:24 PM
EricUSC
Jul 5, 2007 03:05 PM
