Oil Feed line for turbocharger question. What's the safest route in this case?
So I have having issues with the feed line that came into my turbo kit so I made a 90 fitting with brass but my feed line runs under my exhaust manifold has any one every done it this way ? is it safe or should i heat wrap my manifold and place like a head shield on the feed line??
Side note I tied down my feed line so it would not hit the manifold
re: Oil Feed line for turbocharger question. What's the safest route in this case?
You will just be putting a lot of extra heat into your oil, before it goes into the turbo. Not a good thing.
Can you not flip the turbo 180° on the manifold, putting the compressor on the driver's side and bringing the oil feed inlet out in front of the manifold?
I could but the way my down pipe is set up with ruin my set up ..
That might help, but any way you slice it with that turbo orientation you are going to be getting close to the manifold. I might run an oil temp gauge if you are gonna roll like that.
i agree with this, I ran a heat sleeve over the oil feel line that was around 12-14 inch long which should resolve this matter, just don’t let hit touch the manifold
Re: Oil Feed line for turbocharger question. What's the safest route in this case?
Originally Posted by JGTW
what do you think about the me using the brake line for kinda like a 90 degree ?
That's what I'm using for my feed line. They are the same thing, braided hose line for oil/chemicals. You can get another 3AN feed line on eBay for like under $15.
well im going to give it shot this weekend lets see how it turns out
