Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
Old Feb 13, 2019 | 05:05 AM
Jamesyboy's Avatar
Default Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
So in my 97 integra GSR im currently running 330whp on 12psi and im trying to make about 450whp currently the only engine work done is Wiseco pistons and Eagle rods. Before i go blowing anything up i want to know what should be upgraded first, the plan was going to be new retainers and springs with new cams and cam gears new Valves?
Old Feb 13, 2019 | 05:58 AM
TheShodan's Avatar
Moderator
Default re: Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
make sure you have enough injector, your turbo can handle increased boost pressure for 450whp, good fuel and spark. Then turn up the boost..
since we're don't know what you have to start with, we can't say anything further.
Your thread Title was adjusted to reflect a better way to ask your question.
Old Feb 13, 2019 | 07:09 AM
Txdragon's Avatar
Default Re: Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
Originally Posted by TheShodan
make sure you have enough injector..
since we don't know what you have to start with, we can't say anything further..
That.. Right there.. That's about the best that can be obtained without knowing your setup. Post that and watch the magic happen!
Old Feb 13, 2019 | 07:31 AM
Jamesyboy's Avatar
So im running a walbro 255 w/ ID1000cc injectors, EBay Exhaust Mani, Tial 38mm Wastegate and custom dump tube,CX Racing intercooler and custom intercooler piping,Greddy FV BOV, Mishimoto Dual Core Radiator and two fans.
Old Feb 13, 2019 | 11:37 AM
2x0's Avatar
2x0
10 Year Member
I would not take the stock sleeves much past 400whp for long.
If you're on E85 then your fuel system may start to become a limiting factor as well.
Old Feb 13, 2019 | 12:53 PM
Txdragon's Avatar
What turbo? May either need a new one, or just a few cranks on the MBC..
Old Feb 13, 2019 | 02:32 PM
TheShodan's Avatar
Moderator
I said the same thing, just used too many words, I guess.
Old Feb 13, 2019 | 04:37 PM
motoxxxman's Avatar
yup. I'm at 91% duty cycle on ID1050's running e70 at 440hp with aem e85 compatible 320lph pump
Old Feb 13, 2019 | 05:34 PM
Txdragon's Avatar
You're incredibly knowledgeable, sir, but if you determined his turbo can make 450 without knowing what turbo he has, your ******' AMAZING!!! OP never posted info about what turbo he's running..
Old Feb 13, 2019 | 08:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Commas are powerful symbols Txdragon. The Shodan IS amazing, but he did not suggest that the OP's turbo could produce 450 hp.
Old Feb 13, 2019 | 09:07 PM
Txdragon's Avatar
Maybe or maybe not. Lol! I'm not harshing on mac in a bad way here. It's been a long day and he can be vague and transparent all at the same time. On the surface, it seemed to me as if he were suggesting the turbo could, as it was the focus of my statement. As I re-read the comment, he may be stating he said the same thing as I. **shrug** I did not see the suggestion he made anyways, as I posted that response. I post and browse 99.9% from my phone. I meant zero disrespect or discredit in what I said.
Old Feb 13, 2019 | 09:35 PM
Txdragon's Avatar
As you say, the commas are powerful. What I **initially** understood here is that he is pointing out OP's turbo can support 450. I really have to study the statement to rationalize he is suggesting to MAKE SURE his turbo can do so and not suggesting that it can. I like to think my comprehension skills are pretty sharp and this statement seems to have been a curveball for me Lol! My bad!
Old Feb 15, 2019 | 05:39 AM
NVturbo's Avatar
O.G. triple O.G.
replace the ebay manifold and FMIC. That will make a difference for sure.
DougGsrHatch
Aug 4, 2008 05:08 PM
ek9tl
13
Apr 14, 2007 09:49 PM
rUs666
Aug 2, 2006 02:48 PM
rUs666
10
Jul 28, 2006 09:38 AM
808b18c1boosted
Dec 19, 2003 04:08 PM
