Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
So in my 97 integra GSR im currently running 330whp on 12psi and im trying to make about 450whp currently the only engine work done is Wiseco pistons and Eagle rods. Before i go blowing anything up i want to know what should be upgraded first, the plan was going to be new retainers and springs with new cams and cam gears new Valves?
re: Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
Originally Posted by Jamesyboy
(Post 51859663)
since we're don't know what you have to start with, we can't say anything further. Your thread Title was adjusted to reflect a better way to ask your question. |
Re: Suggestions needed: B18c1- What does it take to go from 330whp to 450whp?
Originally Posted by TheShodan
(Post 51859741)
make sure you have enough injector..
since we don't know what you have to start with, we can't say anything further.. |
(Post 51859741)
make sure you have enough injector, your turbo can handle increased boost pressure for 450whp, good fuel and spark. Then turn up the boost..
I would not take the stock sleeves much past 400whp for long.
If you're on E85 then your fuel system may start to become a limiting factor as well. |
(Post 51859929)
So im running a walbro 255 w/ ID1000cc injectors, EBay Exhaust Mani, Tial 38mm Wastegate and custom dump tube,CX Racing intercooler and custom intercooler piping,Greddy FV BOV, Mishimoto Dual Core Radiator and two fans.
Originally Posted by Txdragon
(Post 51860588)
What turbo? May either need a new one, or just a few cranks on the MBC..
Originally Posted by 2x0
(Post 51860501)
(Post 51860670)
I said the same thing, just used too many words, I guess. :shrug:
Commas are powerful symbols Txdragon. The Shodan IS amazing, but he did not suggest that the OP's turbo could produce 450 hp.
Originally Posted by JRCivic1
(Post 51860917)
(Post 51859741)
(Post 51860917)
replace the ebay manifold and FMIC. That will make a difference for sure.
