TPS trouble
Make sure you have the correct harness plug on the TPS. The sensor plugs are not mechanically keyed to prevent plugging them onto the wrong sensor. The one with a solid white wire goes on the MAP not the TPS. There is a sticky at the top of the forum with all the wire colors. It would be good to check the 2 wire ones as well.
