TWM ITB, NEED YOUR HELP!!!!!!
Old Jul 3, 2004 | 09:38 PM
baxter04's Avatar
Default TWM ITB, NEED YOUR HELP!!!!!!
Running the TWM ITB's with 440cc injectors, with Hondata. At wide open throttle, it shuts down. Inputs will be greatly appreciated.
Old Jul 3, 2004 | 11:30 PM
meanEG's Avatar
Default Re: TWM ITB, NEED YOUR HELP!!!!!! (baxter04)
ANY IDEAS, LIKE FUEL SPARK OR REV LIMITER ON WHAT. HOW IS YOUR MAP SENSOR WORKING?
Old Jul 3, 2004 | 11:58 PM
baxter04's Avatar
Default Re: TWM ITB, NEED YOUR HELP!!!!!! (meanEG)
Rev limit is set at 10000 rpm. As for the MAP Sensor, we are running it on a vacuum canister.
I noticed on your signature that you are running the TWM ITB's on your H22. How did you wire your TPS? What Management System are you using?
Thanks
Old Jul 4, 2004 | 01:17 PM
H25's Avatar
H25
you probably have your tps wired wrong. check that over
Old Jul 4, 2004 | 02:01 PM
baxter04's Avatar
Default Re: TWM ITB, NEED YOUR HELP!!!!!! (MHRacing-310)
I did the wiring as per instructions. Same result. And then, I reversed the two outer wires, same result. The voltage at wide open throttle is 6.9 volts but the Honda specs is at 4.4 to 4.85 WOT. Is it possible that the TWM TPS is not compatible with Hondata?
Thanks.
Old Jul 4, 2004 | 02:59 PM
MadnessRacing's Avatar
you probably have the wrong tps i had the same problem with mines and the problems was the tps cause it was opening the opposite way.
Old Jul 5, 2004 | 08:11 PM
AMGTortoise's Avatar
Default Re: TWM ITB, NEED YOUR HELP!!!!!! (MadnessRacing)
Middle wire = signal (red/white)
Right wire = 5v (Yellow)
Left wire = Ground (Blue white)
Old Jul 5, 2004 | 08:19 PM
H25's Avatar
H25
Default Re: TWM ITB, NEED YOUR HELP!!!!!! (AMGTortoise)
the tps is off a ford i beleive for the twm's. just use the one that they give you it works fine..
Brandon Hartman
Nov 21, 2018 02:03 PM
b18swapef
Apr 11, 2009 01:54 PM
SiR HatchAlot
Jan 12, 2004 12:06 PM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
This One
Feb 2, 2003 04:20 AM
