broken tps sensor
Old Mar 31, 2009 | 05:56 PM
chrisff521's Avatar
Default broken tps sensor
I have a cracked tps sensor on my throttle body. is there anyway I can temporarily do a quick fix so that my car will work good?
Old Mar 31, 2009 | 08:22 PM
srmofo's Avatar
Default Re: broken tps sensor
nope
Old Apr 1, 2009 | 05:20 PM
chrisff521's Avatar
u sure?
Old Apr 1, 2009 | 06:02 PM
srmofo's Avatar
wheres it cracked at? and is the car running bad now?
Old Apr 2, 2009 | 03:38 AM
TrboGzR's Avatar
quick fix if u have another honda throttle body lying around. make sure the throttle wire pulley spins the same way. dremel cut slots centered in the middle of the TPS rivets (careful not to cut to deep). loosen with flathead screwdriver and replace TPS.
Old Apr 2, 2009 | 05:31 AM
srmofo's Avatar
thats not a quick fix, that is fixing it....I thought he was just wanting a jumper wire or something......the car will not run right without a tps
Old Apr 5, 2009 | 05:29 PM
shandonwall's Avatar
Either swap TB's with another one or replace the TPS sensor. Then check the resistance at no throttle then again at WOT (wide open throttle). I may be wrong but I think it's .5 ohms at closed throttle and 4.5 ohms at WOT. Does that sound right??
Old Apr 5, 2009 | 07:26 PM
srmofo's Avatar
your close.... its .5 volts closed and 4.5 volts wot
gripek
Honda S2000
12
Feb 22, 2012 10:08 PM
jake1191
Engine Management and Tuning
Jul 18, 2011 06:42 AM
92prelude23
Jan 26, 2009 05:43 PM
nutball72
Nov 11, 2006 07:14 PM
Redsim
Jun 11, 2003 09:37 PM
