98 civic window issue
Old Oct 3, 2018 | 04:12 AM
98civlx's Avatar
Default 98 civic window issue
So I bought a 98 civic cheap its the lx 4 door model. Only passanger rear window works. Driver window was all way down so I bought a new window motor assembly, didnt fix it. It rolled up and down when I supply 12 volts do red/yellow wire and geound red/blue wire or backwards depending on operation. Next thing I assumed was switch. Went to salvage yard got switch and still only rear passenger window works I have not messed with pass front or driver back as they were in up position already. Can anyone please help with this one? All fuses are good. Maybe salvage yard switch bad?
Old Oct 3, 2018 | 04:14 AM
mk378's Avatar
Default Re: 98 civic window issue
Check for broken wires in the driver's door harness. All the window circuits go through it.
Old Oct 3, 2018 | 04:18 AM
98civlx's Avatar
But my rear passanger works. In seriously thinking of making them manual windows
Old Oct 3, 2018 | 04:31 AM
mk378's Avatar
There are separate wires for each window. But they all go to the driver's door.
I don't think it is too complicated to swap to manual windows but you do have to replace the whole regulator assembly at each one.
Old Oct 3, 2018 | 04:40 AM
98civlx's Avatar
Na I'm gonna do it like a boss lol. I got a 97 4 door dx at my parants house front end colision I'm sealing all four doors and gonna drop in my sound system I just gotta wait till sunday
Old Oct 3, 2018 | 11:12 AM
Delicieuxz's Avatar
5 Year Member
There is another recent thread about this issue:
https://honda-tech.com/forums/honda-...indow-3328211/
Old Oct 3, 2018 | 12:59 PM
sumdewd's Avatar
https://honda-tech.com/forums/honda-...-down-3282447/
https://honda-tech.com/forums/honda-...-door-3328075/
Roll the dice. Your window symptoms can be any one of those wires at any of the door jambs. In my case it was both the front driver and passenger sides. Try wiggling your driver's door wire harness while you're moving the switches around. I bet you some of those windows will jump around. I've already done this repair a few years ago. It's holding up quite nicely still. I taped the harness, wire loomed, then taped again.
Just curious.. Why would you go through the trouble of swapping all four regulators when you can repair a couple of wires and add value and convenience back to the car? Don't forget you're also gonna have to cut holes in the door panels or find new ones.
Old Oct 3, 2018 | 01:30 PM
98civlx's Avatar
So I used my light tester with the red/yellow and red/blue wires. Those are the same wires I used jumper wires to the battery to roll the window up. I pushed the wire ends into the pins of the connector at the switch. So I know those wires are good from the switch connector to the motor. Anywho, when the switch is connected and I probe the red/yellow or red/blue wires with my test light I recieve no power indicator. I k ow one of those wires provides power and other is ground depending on switch position so the fact that the switch does not provide power could that mean the switch has failed?
Old Oct 3, 2018 | 02:34 PM
sumdewd's Avatar
Did you try conducting the same test on your rear right window switch wiring? Did you also make sure the other windows weren't disabled with that little master switch thingy turned off?
Old Oct 3, 2018 | 03:10 PM
sumdewd's Avatar
I'm not sure I understood your testing methods, can you clarify?
OP, a better way is to check for continuity according to the FSM if you're still super convinced it's the switch despite swapping it out:
I'm still convinced your door wiring is shot.
Old Oct 5, 2018 | 08:12 AM
Kevs02Accord's Avatar
I second this. Use the above method to test the switch first. All the window wiring goes into the driver do, into the one switch. Its very easy to pull back the rubber boot and see if there are any loose wires. Similar issue happened to me and I had 3 wires that were damaged.
Old Oct 5, 2018 | 08:23 AM
eghatch9295's Avatar
Stancetard Hate Monger
this is a very common issue with the 96-00 sedans. much less work to repair the wiring than to gut all 4 doors and swap in manual parts.
Juliano Rivera
Jun 11, 2019 10:55 AM
Chrisxnj
10
Dec 6, 2016 01:21 PM
Boss727
Mar 15, 2014 08:04 AM
swordofdoom
Honda CR-V & Element
Jul 20, 2013 09:08 AM
JDMEMone
Jun 28, 2012 08:37 PM
