Window switch problem HELP !
Hello I'm new to the forum , I have a 1997 Honda Civic lx
I'm having issues with my passenger window ,
from the drivers door switch the passenger window does not go down or up . But the drivers does
from the passenger switch the window only goes down does not go up ..
what can it be?
what can it be?
Re: Window switch problem HELP !
You have broken wires in the door jam connectors. Be prepare to depin and solder. Or visit the junk yard for replacement harness plug.
when I bought my 98 lx only driver Window work. Lots of broken wires.. Had to take the door off to fix the wires.
Old Fart
Yes, but not cheap, [$80-$100]best bet is your local bone yard, [PicknPull, under $15] lots of Civics at PicknPull.
You can also repair the door jamb wiring, also with PicknPull parts, find the undamaged leads you need, de-pin at the A pillar plug- and cut lead inside the door, no need to remove door, just unplug harness at A pillar, remove door panel and front door speaker, pull harness into door and out the speaker opening, remove wires needed, [I will take the whole plug and cut the leads inside the door] that way when I make the repair the connection, [solder and shrink tube] will be inside the door and not in the boot, I have done this more then a few times when a good harness was not available, you do not even need the same color leads, [the pins will be the same] just do them one at a time if you are replacing more then one lead. 94
Joey Mitchell
10-18-2018 04:59 AM
