Steering gear bearing
Old Sep 17, 2018 | 11:27 AM
Creator's Avatar
Default Steering gear bearing
Hope the pics show up
Has anyone tried to replace #38? If so how did you remove it from the rack & where might I get something to replace the inner lock (#7)?
Old Sep 17, 2018 | 01:25 PM
jsinher3's Avatar
Default Re: Steering gear bearing
If I remember correctly I replaced the bearing and reused the clip.
Old Sep 17, 2018 | 01:27 PM
Tyson's Avatar
i dont remember it being particularly hard to figure out... internal snap ring i think.
Old Sep 17, 2018 | 03:33 PM
Creator's Avatar
The inner retainer is a pinched ring.
I will review the quaife quick steering replacement gear, perhaps find some info there.
Old Sep 17, 2018 | 03:36 PM
Creator's Avatar
Can see it better here
Old Sep 17, 2018 | 04:22 PM
Tyson's Avatar
right... so remove it.
it fits. just make sure youre putting it in a non Si rack.
Old Sep 18, 2018 | 07:21 AM
Creator's Avatar
I'm sure I can remove it, but not without destroying it. I can not find a replacement for it. I'm not putting a quaife in it I'm just looking for the replacement retainer and some info on pulling the pinion bearing out. All the old info on quaife quick gear seems to be gone now.
Old Sep 18, 2018 | 08:46 AM
Tyson's Avatar
I don't remember not being able to reuse it. Just pull it out and try. Reform it if needed.
Old Oct 18, 2018 | 01:55 PM
Creator's Avatar
Just a follow up post for anyone else attempting this.
Cut the ring out and sourced some external lock rings from McMaster-Carr.
I believe the lock ring is to keep the bearing in place during installation.
Played with some heating and cooling combinations to get the pinion shaft out and back in the rack. Same game to remove the old bearing and install the new one.
...esteban
Jul 19, 2016 09:35 PM
10cjennings
14
Aug 17, 2013 08:50 PM
marcosleandros
Honda Civic (2001 - 2005)
10
Aug 18, 2010 10:46 AM
gunterelectric226
25
Mar 10, 2009 08:17 PM
DirtyOldTown
Suspension & Brakes
Nov 2, 2006 09:50 AM
