Cel code 14, help please
Hello, My 92 db1 integra (b18a2 engine, PR4 ecu) Cel code 14.
I changed 3 different IACV, cel code not deleted.
IACV cables are robust. What is the problem?
Like mentioned above most likely you have the wrong plug in the IACV there's other sensor plugs that fit in the IACV, look around to see any other plugs near that might be switched, I also think the IAT sensor has the same style plug and can also reach the IACV so its possible you plugged the wrong plug in the IACV.
terplaygroun_dc2
Oct 23, 2008 09:38 AM
ej2civic
Jan 7, 2007 11:24 AM
