B20z p1399
hey all hopefully someone can help me figure this out.
One of my eks got a b20z swap from the depot and while running the CRV Ecu, at about 3500 RPMS the car believes it’s misfiring (it doesn’t feel like it at all) and then throws a P1399 pending, and then a CEL that’s the only code. I also notice while running this computer the throttle feels like it has hard acceleration and deceleration as if the TPS is no good, although I wouldn’t believe the TPS would cause a misfire, not sure.
To note what I’ve done with the car since the issue first came up I’ll state:
spark plugs
wires
rotor and cap
valve adjustment
sedondary o2
little input or idea would be great, thanks.
Sent via iPhone.
spark plugs
wires
rotor and cap
valve adjustment
sedondary o2
Sent via iPhone.
I've had issues where the tps was off and it was dumping fuel into the cylinders. Gas was shooting out of the exhaust. i recently had to readjust the tps because it was throwing a code, I followed what the fsm suggested but after everything looked good I tried to adjust it and boom, cel gone. It was the cel code for low voltage input or something like that.
uberhaulin
Jun 26, 2006 03:12 PM
