B16/B18 hybrid a.k.a. Poor Man's Type-R engine
Old Jul 24, 2018 | 06:41 AM
SonicC's Avatar
Default B16/B18 hybrid a.k.a. Poor Man's Type-R engine
Anyone on here done one of these builds? I recently acquired a complete B16 swap for a very good price, only downside is the engine has knock. Previous owner thinks it's the rod bearing(s) but I haven't had the chance to open it up yet and inspect. Either way the bottom end will need to be replaced/rebuilt.
Doing some research, it seems like it's possible to bolt up Vtec block from GSR, with different pistons (to increase compression), ITR cams (or BC stage 2 cams), dual valve springs, and a mild port and polish to the B16 head (to match ITR setup) - which would net similar power levels to the ITR b18. Using the online compression calculator it looks like compression ratio of 10.8:1 should be fairly safe (running B18c block and crank, B16 head, USDM ITR pistons (P73), B18 connecting rod, and OEM head gasket). For comparison USDM ITR runs 10.6. It would be tuned with Hondata on 93oct.
So, couple of questions:
1. Would stock USDM B16 ECU be able to run this setup for about 50-100 miles under normal driving conditions (i.e. no hard pulls and taking it to redline)? My state requires emissions testing and it wouldn't pass with Hondata. The idea is to swap in stock ECU, O2 sensors, and cat, drive around to set readiness, pass emissions, then put Hondata back. Does that seem realistic?
2. Could I run a slightly higher compression ratio, something like 11.2 safely on 93 octane without any knock? Reliability and longevity of the engine is the main priority as this car will be used for track and very likely time trials, so I'm not after getting every bit of power out of it.
3. Is 190-200whp a realistic expectation?
Sorry for the long post and thanks in advance.
Old Jul 24, 2018 | 10:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B16/B18 hybrid a.k.a. Poor Man's Type-R engine
Doing some research, it seems like it's possible to bolt up Vtec block from GSR, with different pistons (to increase compression), ITR cams (or BC stage 2 cams), dual valve springs, and a mild port and polish to the B16 head (to match ITR setup) - which would net similar power levels to the ITR b18. Using the online compression calculator it looks like compression ratio of 10.8:1 should be fairly safe (running B18c block and crank, B16 head, USDM ITR pistons (P73), B18 connecting rod (You MUST use a GSR/ITR connecting rod, as in B18C1/5), and OEM head gasket). For comparison USDM ITR runs 10.6. It would be tuned with Hondata on 93oct.
It likely wouldn't pass emissions with the B16A ECU... you would probably be better off trying to use an ITR (P73) ECU to get the car tested.
2. Could I run a slightly higher compression ratio, something like 11.2 safely on 93 octane without any knock? Reliability and longevity of the engine is the main priority as this car will be used for track and very likely time trials, so I'm not after getting every bit of power out of it. A good tuner can make that happen.
3. Is 190-200whp a realistic expectation? Depending on the dyno... yes, realistic.
Old Jul 25, 2018 | 03:22 AM
2x0's Avatar
2x0
10 Year Member
This is the same setup I am running currently, except with GSR cams instead of ITR.
I agree with JR, it probably will need a basemap/ecu from a GSR or ITR to run decently.
Old Jul 25, 2018 | 05:17 AM
SonicC's Avatar
JRCivic1
I did mean to write B18c connecting rod, I figured non-vtec b18 rod wouldn't work anyway. Didn't even think of running ITR ECU...I'll have to see if it's even possible to hunt down one of those. Per post below, maybe GSR ECU would work as well?
Thanks for the info!
How do you like your setup and how is it with GSR cams? What ECU/tune are you running?
Old Jul 25, 2018 | 05:55 AM
2x0's Avatar
2x0
10 Year Member
I probably can't give you an accurate review since I have only had the setup with turbo. But it feels great even when not in boost. Has been very reliable.
I'm running Hondata S300 v3 on a P28.
Old Jul 25, 2018 | 07:41 PM
SonicC's Avatar
Thanks for the info, man. I tried to find some people locally who may have done similar builds, but it seems all the hybrid builds are LS/Vtec
Old Jul 26, 2018 | 02:21 AM
NVturbo's Avatar
O.G. triple O.G.
It's 2018. This swap has been done 10 million times since the early 2000s.
Old Jul 26, 2018 | 03:46 AM
2x0's Avatar
2x0
10 Year Member
It seems like it was pretty popular 10-15 years ago but has tapered off since. It is hard to find much info on them more current than 2010.
And technically you were supposed to use type R internals to call it a true "poor man's type R" but whatevs
Old Jul 26, 2018 | 04:24 AM
SonicC's Avatar
Yes?
Have you done it?
As long as it makes good power
werebacke
Aug 26, 2010 10:49 PM
Jxi8s2k
Dec 22, 2005 07:12 AM
sir91
12
Apr 22, 2004 10:54 AM
SIReg9
Nov 6, 2002 10:34 AM
Dodger2940
Aug 25, 2002 12:10 PM
