HELP!!! SCHA is loose
Old Jul 16, 2018 | 08:50 AM
SCMFOX's Avatar
Default HELP!!! SCHA is loose
so puttin together my S80 tranny backtogether and I notice my SCHA has some play to it, it’s bolted down and aligned with the shifting forks but with enough effort it can come undone. Is this normal? Will the housing hold it together?
Old Jul 16, 2018 | 01:41 PM
Relic1's Avatar
Default Re: HELP!!! SCHA is loose
for those of us that don't typically go that deep.... what's a SCHA
come undone from the shift fork or the case?
likely to get more accurate response in this sub-forum --> transmission and drivetrain
Old Jul 16, 2018 | 04:06 PM
GreatWave's Avatar
10 Year Member
The outer case should hold the shift selector in place, but make sure it's all lined up before the case is bolted down. You should never have to pull both halves together with the bolts.
Dr.Fixit
Oct 22, 2013 12:42 AM
NoWorry's
Transmission & Drivetrain
Apr 5, 2013 03:45 PM
MikeY326
Dec 27, 2009 10:35 PM
leprechan117
10
Apr 12, 2003 04:02 AM
AmauryR
Feb 19, 2002 07:04 PM
