Doing a auto to manual swap...motor mount post question
Old Jul 12, 2018 | 02:38 PM
metalslug's Avatar
Default Doing a auto to manual swap...motor mount post question
So I have a d16 from a manual car and putting it in my auto chassis. Not done all the way, as I see that the two post bracket is narrower on the 5 spd swap than the one on the auto long block. Is the only way to fix this is to swap the post, or to get a mount that fits the narrow post? Or is it being that it's a auto chassis only swapping the post will work?
Thanks in advance.
Old Jul 12, 2018 | 11:16 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Doing a auto to manual swap...motor mount post question
i've done a few of these, and they use the same post mounts. the bracket is different.. my guess is that someone swapped out the post for a different gen civic, so yes, change the post mount out.
Old Jul 13, 2018 | 04:48 AM
metalslug's Avatar
Ahhhh, thanks. Easy enough. Also quick question, will the 96-00 pedals, like clutch and brake fit a 92-95? I have these available, though I would ask.
Old Jul 14, 2018 | 10:52 PM
i know the clutch does, unsure on the others.
lazymbf
11
Jul 15, 2025 03:17 PM
GSR_hatch936
Transmission & Drivetrain
Apr 1, 2014 04:44 PM
Yonick90
12
Feb 5, 2010 06:26 AM
SprayinCX
10
Jun 10, 2004 11:33 PM
JD_B18CDX
May 12, 2002 10:55 PM
