High fuel pressure on stock fpr
Okay so I’m seeing about 80-90 psi at the rail with a stock fpr. What could cause this?
i have a walboro 450 hardwired to the battery, 2200cc injectors, and an AEM fuel rail.
Your walbro 450 has too much flow for a stock fpr. You need to run an after market fpr for that pump, I recommend an off rail regulator like aeromotive or equivalent.
i have an AEM one but I was trying to figure out that issue.. guess I’ll just throw on my that one then. Thanks!
The aem regulator come with 3 different size internal fittings. You probably want to use the largest one with that pump. I wasn’t able to run more then 45psi base pressure with my walbro 450 and aem regulator without the pressure jumping around like crazy, so I switched to an off rail regulator and have no problem running 65psi base pressure now.
jdmhondak9
38
Jul 28, 2013 10:24 AM
danmej1
Nov 5, 2010 06:33 PM
saer
Jun 3, 2005 04:17 PM
