High fuel pressure on stock fpr
Old 06-10-2018, 01:13 PM
Default High fuel pressure on stock fpr
Okay so Iím seeing about 80-90 psi at the rail with a stock fpr. What could cause this?
i have a walboro 450 hardwired to the battery, 2200cc injectors, and an AEM fuel rail.
bcintron95 is offline
Old 06-10-2018, 01:21 PM
Default Re: High fuel pressure on stock fpr
Hopefully you guys can tell me if I have something horribly fucked up
Old 06-10-2018, 01:36 PM
boosted94gsr's Avatar
Your walbro 450 has too much flow for a stock fpr. You need to run an after market fpr for that pump, I recommend an off rail regulator like aeromotive or equivalent.
boosted94gsr is offline
Old 06-10-2018, 02:18 PM
i have an AEM one but I was trying to figure out that issue.. guess Iíll just throw on my that one then. Thanks!
Old 06-10-2018, 05:35 PM
The aem regulator come with 3 different size internal fittings. You probably want to use the largest one with that pump. I wasnít able to run more then 45psi base pressure with my walbro 450 and aem regulator without the pressure jumping around like crazy, so I switched to an off rail regulator and have no problem running 65psi base pressure now.
Old 06-13-2018, 02:47 AM
O.G. triple O.G.
NVturbo's Avatar
AEM FPR are garbage. Get one from Aeromotive and your issue should be resolved.
NVturbo is offline
drumminforev
09-16-2006 10:20 PM
importdude2000
08-31-2006 08:54 PM
ceemarun
08-22-2002 01:09 PM
Quick Reply: High fuel pressure on stock fpr
  • Ask a Question
Question Title:
Description:
