Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Oil cooler mounting -Optimal location JDM ITR Front end
Old 06-12-2018, 05:06 PM
Default Oil cooler mounting -Optimal location JDM ITR Front end
I just Boosted my 98 Itr and Iím having air flow problems to my half size Koyo Radiator. So Iím in the process of moving my oil cooler from the front of my car to the passenger side wheel well so I can make some shrouding to direct air flow to the radiator. So my question is can I mount my oil cooler upside down ( as in the AN port are pointing down)?
jerzey908 is offline
Old 06-12-2018, 07:34 PM
Moderator
TheShodan's Avatar
Default re: Oil cooler mounting -Optimal location JDM ITR Front end
No. Although your location is sound, you cannot invert the cooler. It can have the inlet/outlet ports sitting at the top or at a 90* angle. But not inferred as you're describing.
TheShodan is offline
Old 06-13-2018, 02:31 AM
why? The reason I ask is because I been looking at this for days and the best way I think to mount it (not saying itís the right way) where it will get the best air flow is with it upside down. I could mount it right side up but my intercooler piping is in the way and the an fitting will be hitting the frame rail
Old 06-13-2018, 03:50 AM
Moderator
TheShodan's Avatar
Oil pressurization will cause it to back flow. I have airfoil coolers on both of my B-series engines in JDM DC2 and EM1 chassis ( 19 row Earl's & Setrab coolers using Mocal sandwich plates with integrated oil thermostats using -10AN lines.)
Talking from experience. Sorry.
Old 06-13-2018, 08:30 AM
well that suck. I thought I ask because I been doing research and I seen people say yes and no. Whatís a airfoil cooler?
Old 06-13-2018, 10:12 AM
I hear upside down is the worst, although my friends 06 didge viper has this stock, an upside down oil cooler no joke.
I mounted mine sideways I hear this is best, feed in the top, return on the bottom.
Cupajoe is offline
Old 06-13-2018, 11:07 AM
Where I want to mount mine I have no room to mount it upwards or vertical to maximize airflow. I can mount it either those two was but no air flow will get to the cooler. Will just blow right past it in my opinion.
If mount this way air will flow right past cooler
If I can mount this way which will but the cooler upside down air flow will go right through the cooler and will utilize my air duct I have in my bumper already
Old 06-13-2018, 11:19 AM
Change the location that you are mounting the oil cooler or run a smaller cooler? I boosted my em1 and my oil cooler about the same size as yours is on the right side where the ac condensor used to go.
Cupajoe is offline
Old 06-13-2018, 12:33 PM
thatís where I had it mounted but Iím having airflow issues to my radiator and need to build shrouding to direct air to it so oil cool need to be moved
Old 06-13-2018, 06:45 PM
Moderator
TheShodan's Avatar
mistype from another device.. I meant air-cooled oil cooler
Old 06-13-2018, 06:55 PM
Moderator
TheShodan's Avatar
[QUOTE=jerzey908;51658499]That's a JDM ITR front end. I have a custom bracket angling the oil cooler on the driver's side (U.S.) So that it's facing forward. I cut out one of the lower ducts to allow air flow directly to the cooler. Notice how the inlet/outlet ports are still mainly facing upward.
Old 06-14-2018, 02:42 AM
Default Re: Oil cooler mounting -Optimal location JDM ITR Front end
I see how you did yours but on my bump I already have a jís racing air duct installed from when I was N/A so Iím trying to utilize it. But my intercooler piping is in the way. I can mount it how I have it in the second pic I post but vertical but I will have to drill a whole in the frame rail for one of the -AN line and Iím trying not to do that. All of this because my half size radiator is not getting air flow and if I canít fix that problem Iím going to have to squeeze a full size radiator in the car and the oil cooler is definitely going to have to move.
Old 06-14-2018, 02:46 AM
[QUOTE=TheShodan;51658800]
do you have a pic of how itís mounted with the bumper off?
Old 06-14-2018, 05:32 AM
Moderator
TheShodan's Avatar
Not right now. I'll try for one in the coming days.
Can't have it all, man.. J's duct or oil cooler.. Might have to make a choice. .My I/C piping also gets in the way on the passenger side.
Old 06-14-2018, 07:01 AM
it wonít work for me on driver side since thatís where my filter for my turbo is plus intercooler piping. And a pic would be awesome
Old 06-14-2018, 07:42 AM
why not just run a small motorcycle fan on the oil cooler, like off a sv650.
Or you could do this
Cupajoe is offline
Old 06-14-2018, 08:23 AM
lol.. no to the pic
Old 06-14-2018, 08:59 AM
I just talk to a rep at Mocal and he stated it doesnít matter which what you mount the cooler. He said you just donít want to mount it high enough that it will drain back if you plan to mount it downwards.
Old 06-14-2018, 10:43 AM
Moderator
TheShodan's Avatar
Alrighty then... I wish you good luck and Godspeed, sir.
jDMJeRk
09-14-2005 02:28 PM
canuck-mx6
10-16-2003 06:48 AM
Quick Reply: Oil cooler mounting -Optimal location JDM ITR Front end
  • Ask a Question
Question Title:
Description:
