Suspension & Brakes Theory, alignment, spring rates....
Drivers side rear drum not bleeding.....why not???
Old May 21, 2018 | 04:47 AM
Baby99EX's Avatar
Default Drivers side rear drum not bleeding.....why not???
Like the title says, but the line itself is good, and other 3 bleed fine, but why wont this one?? Please help!! Thanks.....
Old May 21, 2018 | 09:13 AM
Tyson's Avatar
Default Re: Drivers side rear drum not bleeding.....why not???
what did you try to help figure out the problem?
Old May 21, 2018 | 12:12 PM
Baby99EX's Avatar
bleeding the brakes, and DR has no fluid AT ALL, checked the lines under the car no bends or kinks but who knows i really dont want to try n pus a new one of those in.......dont know what else.......
Old May 21, 2018 | 12:16 PM
Tyson's Avatar
how can we help?
Old May 21, 2018 | 01:25 PM
Baby99EX's Avatar
i dont know what to do next really.......any recommendations r welcome, please and thanks......
Old May 21, 2018 | 01:59 PM
Tyson's Avatar
do you have any brake pedal resistance when pushing on the pedal? somewhat normal? or just goes to the floor?
unbolt the line to the drum. does fluid come out?
if so, replace the brake cylinder. if not, your problem is upstream. which would be a blockage in the hard lines or a problem with the prop valve. disconnect the prop valve, and see if you can blow fluid down the hard line.
Old May 21, 2018 | 03:41 PM
Baby99EX's Avatar
yes, there is some pressure in the pedal it doesnt go all the way to the floor.........what do u mean by prop valve? sorry.......
Old May 24, 2018 | 10:39 AM
Baby99EX's Avatar
u mean that little block on the firewall that all the brake lines go to??
Old May 24, 2018 | 11:57 AM
Tyson's Avatar
do you have ABS?
Old May 25, 2018 | 06:53 AM
Baby99EX's Avatar
Nope, no ABS.......EX.......
Old May 25, 2018 | 08:07 AM
KDerekT83's Avatar
take off the drum and verify you don't have a bad/leaking wheel cylinder or some broken hardware in there also...
Old May 25, 2018 | 08:08 AM
Tyson's Avatar
Then yes, that is the prop valve .
SiHatchTurbo
Aug 25, 2010 07:20 PM
crip
10
Apr 1, 2010 05:14 PM
red96civicex
Suspension & Brakes
Dec 11, 2009 09:18 PM
PhatFactory
35
Oct 23, 2009 06:09 PM
OKSolSi
Apr 20, 2004 08:13 PM
