Troubleshooting: Misfire codes after P&P, Tuner1, Valve and Piston swap. Thoughts?
2000 Type R Integra Engine just completely rebuilt. A little polish/porting done to cylinder head. Slightly larger valves and pistons. Skunk2 Tuner Stage One C.A.R.B. legal cams. Engine runs fine but computer states misfiring on all four cylinders. Any ideas ? ? ?
Yeah. once you change the pistons, the whole ignition and fuel timing changes. You need management. No stock ECU for you.
This has been moved to the engine management forum. Please do not post this in multiple forums
Any recommendations on what new ECU would work well and/or someone in the Los Angeles area who is competent to do the work
Head to the top of the forum. In the grey areas there should be a tuner list to look up in your area.
And keep in mind, you're in CA, meaning very strict emissions laws. So nearly everything you can do for tuning will be highly illegal in your area if you drive it on the street. Just food for thought, and part of why I'll never live in CA
Megalodong
Engine Management and Tuning
Jul 23, 2017 06:50 AM
Hardedge
Nov 14, 2007 11:30 PM
