endyn rollerwave pistons
Old Dec 24, 2001 | 03:31 PM
slowpoketeg's Avatar
Default endyn rollerwave pistons
who has experience with these and can i just bolt them on a stock type R w/o any fuel adjustments? while im changing the pistons should i change out the valve springs or retainers for the hell of it?
Old Dec 24, 2001 | 03:35 PM
RagingAngel's Avatar
Default Re: endyn rollerwave pistons (slowpoketeg)
HAha....sorry...
bolt them on.....
wish it was as easy as you stated....though it's not that much harder....
Anybody here? They offer standard bore now too don't they?
if it's all apart, and you have the means, get retainers and valveseals done ....but that ofcourse could vary with mileage and use.....
Old Dec 24, 2001 | 03:47 PM
Darin D.'s Avatar
the only reason you would need to upgrade valvetrain is if you were installing higher lift cams or plan on running your engine past the factory redline. Installing rollerwave pistons would not require any additional modifications. From the way it sounds..you won't be the one installing the pistons, so ask your mechanic lots of questions and maybe even watch him doing the work. You can learn a lot this way.
Old Dec 24, 2001 | 11:53 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: endyn rollerwave pistons (Willis)
incorrect info...........
what if new cams had same total lift, but higher ramp angle?
You would need stronger springs to maintain full contact.
Just a V8 point of view.
070-racing
Oct 26, 2014 04:55 AM
JDM_home
Jul 19, 2012 10:11 AM
keep_up
May 31, 2007 06:42 AM
BABY NSX
Sep 20, 2001 08:05 PM
