99 EX won't start....quick ?.....
Old Dec 5, 2017 | 05:00 AM
Baby99EX's Avatar
Default 99 EX won't start....quick ?.....
Hi, We took the thermostat out, now it won't turn over, is that why? nothing else was changed and it started and ran fine right before this.....thanks....
Old Dec 5, 2017 | 05:57 AM
mk378's Avatar
Default Re: 99 EX won't start....quick ?.....
It won't crank, or it cranks but won't start? In the latter case, check the ground wires on the thermostat housing.
Old Dec 5, 2017 | 06:43 AM
tony_2018's Avatar
Fish Twig
ecu ground wire missing.
Old Dec 5, 2017 | 07:02 AM
Baby99EX's Avatar
what??
Old Dec 5, 2017 | 08:41 AM
civic402lx's Avatar
Check what he said. Ground wireS, on the t-stat housing. Google it if you dont know what it is.
Old Dec 5, 2017 | 08:43 AM
mk378's Avatar
There should be 3 or 4 small black wires that come together into a single lug connected to a bolt on the thermostat housing. Those wires ground the ECU system. If it is not connected, the car will crank but not start.
Old Dec 5, 2017 | 09:26 AM
Baby99EX's Avatar
It won't evan crank now, but i will try to get that bolt on the thermostat housing........
Old Dec 5, 2017 | 09:51 AM
mk378's Avatar
If it doesn't crank, that's a different problem. Check that you didn't pull the wire off of the starter by accident. If the starter makes noise but doesn't turn, check that the engine is not seized.
Old Dec 5, 2017 | 10:57 AM
Baby99EX's Avatar
its NOT rom having the thermostat out tho right??
Old Dec 5, 2017 | 11:24 AM
mk378's Avatar
No. Taking the thermostat out doesn't really help anything though.
I assume it has been overheating, which is why I suggest checking that the engine is not seized or hydro-locked by turning it by hand with a socket on the crank bolt.
Old Dec 5, 2017 | 04:08 PM
Baby99EX's Avatar
It was the starter ground......i took it off, sanded it with sandpaper put it back on and it started right up......thanks fellas.
Old Dec 7, 2017 | 03:09 AM
tony_2018's Avatar
Fish Twig
Starter doesn't have a ground wire, it grounds through the starter chassis
Old Dec 7, 2017 | 03:44 AM
Baby99EX's Avatar
Umm, it has a screw on it that goes to a ground and thats what it was was a corroded terminal.......
Jeremy Harris
21
May 2, 2016 10:58 AM
soLaLive
Dec 8, 2010 03:13 PM
909ej195
Oct 9, 2006 08:31 PM
angcurdy
Aug 14, 2004 11:08 AM
DemonHippie
Jul 20, 2003 12:58 AM
