engine wont start
Old Oct 6, 2006 | 01:19 PM
909ej195's Avatar
Default engine wont start
wus up yall i just bought a car the other day and now it wont start what could it be. My friend thinks is the disterber cap that not fireing so what is yall opinion thanks,,
Old Oct 6, 2006 | 01:39 PM
Perfectionist's Avatar
Default Re: engine wont start (909ej195)
yo sup, just bought a car? Could be anything. Not enough detail. Try again.
Old Oct 6, 2006 | 04:43 PM
HondaDriver85's Avatar
When you go to start it does it crank at all?????? and if it does you can check the distributor out by pulling one of you spark plug wires and seeing if there is spark when ur cranking... You gotta be careful though or you can shock yourself pretty good...
Old Oct 7, 2006 | 12:40 PM
2slowGs-R's Avatar
it could be the coil in the distributor...im pretty much sure thats it or if your car dont even crank check out for the grounds...the most important ground is the one found on the thermostat....if it doesnt crank than get a thick speaker wire and directly ground it from the negative terminal straight to the thermostat housing ground! check! just my .2 cents
Old Oct 9, 2006 | 07:33 PM
P@sscard's Avatar
if there is no spark it could be the coil
Old Oct 9, 2006 | 08:31 PM
db8vtec's Avatar
Default Re: (P@sscard)
need more detail.... if rotating... check for spark?/ .. put a srewdrive in teh spark plug wires and put the srew driver close to a metal... like a small gap to see if there spark when u try to crank it.... if no spark... test ur coil, i say its teh coil.. happen to me....
if there spark, check fuel> or else.. u might be off timinmg ot igniton modulator is bad... get that test at autozone for free
if it dont rotate then check for power, starter, ground, if its a 5spd, make sure is press all teh way in... if so and still dont work... check that clutch pedal switch.
make sure there gas.....hehee
hope this help....if not .. sorry...
teal91
Dec 5, 2008 04:45 PM
Diyracing2
Jan 2, 2007 07:43 AM
btrim23
Apr 24, 2004 04:52 PM
gLotex70
May 31, 2003 01:30 AM
blackhatchy
18
Apr 13, 2003 05:27 AM
