Shuts off
Old Oct 24, 2017 | 03:42 AM
KaylaKiauna1's Avatar
Default Shuts off
2000 Honda Accord LX car shuts off while at red light or while turning, the car shakes pretty hard before cutting off to warn me, sometimes I don’t get a warning. I got a new alternator, battery cables, fuel filter, spark plugs & spark plugs wires, got the battery, alternator & started tested & they were pretty good, what else could it be ?
Old Oct 24, 2017 | 09:45 AM
somick's Avatar
Default Re: Shuts off
You did not mention a distributor cap. Has it been checked?
If it has everything is pointing out to you ignition switch.
Good luck,
Sam
Old Oct 24, 2017 | 01:27 PM
Thank you so much for replying, how do I go by getting the distributor cap checked ?
Old Oct 24, 2017 | 01:49 PM
holmesnmanny's Avatar
have the car scanned for codes
Old Oct 24, 2017 | 03:23 PM
The codes that popped up where
1.VTEC system malfunction
2.Catalyst Efficiency Below Threshold
3. A/T (TCM) 2nd Pressure Switch Circuit Malfunction
Old Oct 24, 2017 | 10:38 PM
It's possible that catalytic converter is bad and the exhaust is backed up(clogged). You can try removing the oxygen sensor just to see if it helps the exhaust to breathe and see if it runs better.
Old Oct 24, 2017 | 10:58 PM
Spudz76's Avatar
Ignitor inside the distributor. AKA "ignition module"
Expensive as heck from new part stores, I get mine from the u-pull as they fit nicely in pockets while I buy some $2 chunk of trim. I take like 4 of them in case 3 don't work and so I have more spares. I could get you a few for the cost of shipping, next time I go.
Old Oct 25, 2017 | 06:31 AM
Do you think that’s the problem, the ignition module ?
Old Oct 25, 2017 | 05:06 PM
tamboo's Avatar
10 Year Member
they dont last forever that's for sure lol.
prone to heat failure. usually dead within 100k miles.
usually you'll get tachometer freakout when it's biting the dust.
just replaced mine with an airtex unit from rockauto.
reasonably priced and supposedly built to withstand the heat.
working great so far we'll see....
Old Oct 30, 2017 | 01:04 PM
Spudz76's Avatar
Every single one I've borrowed as a spare from the junkyards had no heatsink thermal compound underneath. When I install them I add appropriate smear of Arctic Silver or equivalent ceramic thermal transmission grease (same as computer heatsinks).
Old Oct 30, 2017 | 03:57 PM
tamboo's Avatar
10 Year Member
yeah the airtex unit came with a little packet of it.
definitely essential.
Sami1
Jun 6, 2019 04:51 PM
tinavagurly
Dec 15, 2017 09:38 PM
ieetgluu
Jul 6, 2016 05:55 AM
98oRange
May 23, 2005 11:03 AM
nwdave
Jun 30, 2004 03:10 PM
