Suspension & Brakes Theory, alignment, spring rates....
Koni RACE shocks on CRX
Old Oct 2, 2017 | 08:37 AM
CroSi's Avatar
Default Koni RACE shocks on CRX
I bought Koni race shocks (shorter ones) for my 91 CRX and I am wondering what length of spring I should order with my GC kit.
I will be changing the springs if I hit the track so i’d like to know what spring rate is good for the street and track. I’ll be buying 2 sets of springs.
Old Oct 3, 2017 | 05:08 AM
DumpdEJ6's Avatar
I like the tuna here
Default Re: Koni RACE shocks on CRX
What type of racing?
Old Oct 3, 2017 | 08:36 AM
CroSi's Avatar
Time trials
Old Oct 6, 2017 | 04:17 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Correct spring length depends on rate and how much you want to drop it.
I used anywhere from...5.5" to 8" springs on my Koni/GC setup on my ITR. Rates from 400LB to 570LB.
Spring rates take a lot of experimentation...and it depends heavily on type of tires, other setup items, car weight, shock valving, etc. People might shout out what worked for them. But...it only worked for them (or so they'll claim).
Old Oct 7, 2017 | 10:31 AM
KiNGDEE206's Avatar
It's not smart to drive koni race shocks much on street fyi. But like other guy said spring rates very on experiment. I no for dd I like 350-400 for both front and rear you just get a feel..
i think 350/350 is even ride. Again you cannot should not drive koni race coilovers on streets too much. Even lee from koni said so and voids warranty
keep koni race for track only driven
but spring rates for track usually people get 500-600f/500-750rear depending on application
Old Oct 8, 2017 | 11:07 AM
CroSi's Avatar
Thanks!!
Old Oct 9, 2017 | 08:27 AM
.Manny.'s Avatar
Touching My Member
I run 7" Tall, 700lbs springs in the front. 8" Tall, 650lb springs in the rear.
1990 Civic Hatchback. Track only.
Old Oct 9, 2017 | 09:55 PM
AndyM360's Avatar
Koni race shocks are valved to handle rates of 550+. You will want to run atleast no less than 650lbs for the racing you want to be doing. Spring rate depending on your driving style, and the balance you want.
Old Oct 14, 2017 | 04:03 AM
CroSi's Avatar
How would the ride be on the street with the Konis set to full soft with spring rates 400f 350r ?
Chillinit
Nov 25, 2009 11:11 AM
Crimson_Tide
Oct 5, 2005 08:31 AM
anekin007
May 28, 2004 03:18 PM
performula
Oct 21, 2002 05:38 AM
shpae
Dec 17, 2001 10:18 PM
