Just finished a swap in 2000 si, Not idling, running rough
Old Sep 24, 2017 | 06:43 AM
Nitrozity74's Avatar
5 Year Member
Default Just finished a swap in 2000 si, Not idling, running rough
Hi i was looking to get some help, i just finished a B18 ls swap in a 2000 si. Harness is off of a 99 civic dx. I have everything plugged in, tps, map, iacv, etc.. I have heard about the 2 to 3 wire conversion on the iacv but is that necessary for the setup i have? Currently has a stock intake manifold on it aswell with a 2 wire iacv.
Old Sep 24, 2017 | 06:53 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Just finished a swap in 2000 si, Not idling, running rough
Check your firing order.
Old Sep 24, 2017 | 09:46 AM
tony_2018's Avatar
Fish Twig
Yes its necessary, not sure how the **** you plugged in the iacv
Old Sep 24, 2017 | 02:06 PM
trinib20's Avatar
did u reuse the vtec head ?
what ecu ?
stock intake b16 or b18b?
Old Sep 25, 2017 | 05:29 AM
5 Year Member
Yes its the stock ls intake with a 2 wire iac. Not vtec yet, using a chipped p28
Old Sep 25, 2017 | 06:31 AM
mk378's Avatar
+1 You have to rewire for the IACV. If you somehow plugged the OBDII DX harness into a 2 wire IACV you're using the wrong plug.
Check all the sensor plugs by wire color. The connectors are not physically keyed, it is possible to plug them into the wrong things.
Old Sep 25, 2017 | 08:48 AM
mattvivsound's Avatar
I'm scratching my head here... but Why did you go from a B16 (VTEC) to a B18 (Non-VTEC)? That seems like a down grade.
Old Sep 25, 2017 | 09:53 AM
5 Year Member
I bought the car as a shell for a pretty good deal and had a b18 ls laying around in my garage. Right now its kind of a budget build im trying to use what i got and make it run. Future plans are to go lsv. And i do have a jumper harness connected from my harness to ecu to make this conversion work.
Old Sep 25, 2017 | 10:35 AM
tony_2018's Avatar
Fish Twig
motor lost compression on my em1 when I bought it, prev owner probably boosted the **** out of it.
I dropped in a b20.
fastrxu
28
Feb 17, 2009 05:36 PM
jethatch
Jun 7, 2008 12:27 PM
dc4_wHORE
Nov 28, 2006 07:14 AM
HondaTeg95
Apr 20, 2006 01:11 PM
EM1_
Jan 30, 2006 09:38 PM
