Axle Won't Fully Slide In
Old Sep 13, 2017 | 04:42 PM
MastaFlyMason's Avatar
Default Axle Won't Fully Slide In
CRX with B18a1 OBD1 engine swap. I can't get the driver side axle to slide in. I bought a 93 Integra axle. It fits partially but won't go fully in. Tried taking the C clip off, same thing. Other one went in without an issue and I've tried for a while it just won't go. Could I have the wrong intermediate shaft? Only thing I can think, not sure if a later int shaft would be close enough to fit but not slide in fully though. Let me know what you think, thanks
Old Sep 13, 2017 | 07:06 PM
m4xwellmurd3r's Avatar
Default Re: Axle Won't Fully Slide In
Make sure that your driver side axle has splines going all the way down the shaft. I bought a "driver side" axle and was given a passenger side axle. The passenger side's splines only go half way to form the sealing surface for the axle seal.
Old Sep 13, 2017 | 07:36 PM
You're right, that's what happened. Thank you, I'd never of figured it out
OmgDelSol
Sep 10, 2014 02:16 PM
integrainside
Transmission & Drivetrain
Oct 3, 2013 05:21 PM
appelsos
Jun 27, 2011 07:29 PM
Endo-land
Sep 9, 2007 08:12 AM
B18CYAAA
Aug 11, 2007 04:38 PM
