Civic randomly dies
Old Aug 16, 2017 | 03:17 PM
Jeremy Dunn's Avatar
Default Civic randomly dies
So the other day I got into a little accident in my vehicle. At the time all I saw was that i needed a new tire and rim after hitting debris on the road. However ever since that day car has been stuttering a lot and today its been dying a lot. I will be at a red light and its at idle and as soon as i go into 1st gear and try to drive the car will stutter immediately and just die even if i give some gas. It was a little embarrasing so I decided to rev up to about 5k rpm and nothing would happen as long as i came off the clutch slow. later on today as im on the highway it will just start to die out unless i floor it. Would this still be a fuel pump issue or have i possibly messed something else up?
Old Aug 16, 2017 | 03:18 PM
Default Re: Civic randomly dies
Ive checked most of the visible wires and I can hear the clicking sound from turning it into accesorry mode and it still starts
Old Aug 16, 2017 | 07:11 PM
civic402lx's Avatar
When was the last time the fuel filter replaced? Could be a dying fuel pump.
clogged fuel filter
clogged injectors
etc..etc..
Old Aug 16, 2017 | 07:22 PM
I will be getting a new fuel pump tomorrow and 2 fuel filters 1 for when i run seafoam through and then the 2nd as a normal replacement. The injectors turned out okay at idle. I did the screwdriver thing and even unplugged each injector one at a time during idle to make sure all were working and they checked out okay, Ill post the results tomorrow after the fuel pump and filter replacement
Old Aug 17, 2017 | 06:44 PM
civicservice's Avatar
What do your fuel trims look like at idle and under load?
Old Aug 18, 2017 | 05:01 AM
amerc's Avatar
If you have starting issues in addition .. could be the ignitor (inside the distributor).
Old Aug 18, 2017 | 10:33 AM
UPDATE:
I only did the fuel filter replacement and the dying issue is gone for the moment. I drove around for about 20 miles to test it out. However, it does still stutter under light acceleration, as in I put my foot on the gas just a little bit and feel the hesitation. I Replaced the entire ignition system when I got the car back in march( it was an abandoned car) The only codes I get are random misfire and cylinder misfires in 1 and 3. I havent done a valve adjustment yet but i plan on it when I have the time. I dont know the fuel trim of my car. But once the car does a struggle start in the morning it starts right up. The cold start is pretty nasty and at idle its so quiet its like the car is off but there isnt any shaking or anything. Its just super quiet.
Old Aug 18, 2017 | 10:34 AM
I do have a collapsed hose from my intake manifold but I have no Idea what or where that hose goes to. I Just know it leads to the back of the block somewhere.
PePe240sx
18
Sep 13, 2011 06:41 PM
hermtm2
23
Apr 8, 2009 06:17 PM
islnder102
Sep 26, 2006 01:08 PM
Xenobi
Jan 26, 2006 09:24 PM
ThrillaKilla
Apr 1, 2003 11:17 PM
