B18 swap 00 civic help
Old Aug 11, 2017 | 01:21 AM
jspinelli8's Avatar
Default B18 swap 00 civic help
I recently bought a b18b1 from a 99 teg (obd2a) and am planning to put it in my 00 civic ex coupe (obd2b) and im not sure what to use regarding the harness and ecu i've heard keeping the d16 harness and using the p75 from the teg should work but there seems to be mixed Opinions. And if i do this will i need something to convert from obd2a to obd2b? All help is appreciated thanks
Old Aug 11, 2017 | 01:40 AM
jspinelli8's Avatar
Default Re: B18 swap 00 civic help
And if i was to want to be able to tune it would my only option be some kind of standalone ecu
Old Aug 11, 2017 | 07:09 AM
theYBLEGAL's Avatar
Loved
You must go obd1 if you plan to tune
Only way to tune Hondas on obd2 are k-series motors
Old Aug 11, 2017 | 08:25 AM
jspinelli8's Avatar
Thanks, so i should use the obd1 p75? And do i use the civic harness with an obd1 conversion?
Old Aug 11, 2017 | 10:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, an OBD-1 P75 ECU with a tuning solution and a OBD-2B -> OBD-1 conversion harness makes it plug and play at the ECU end. You use the engine harness from the '00 EX coupe and modify it to fit the engine... changing clips/connectors and shortening/lengthening wiring as necessary.
Old Aug 11, 2017 | 11:17 PM
jspinelli8's Avatar
thanks for the help
Old May 7, 2018 | 06:07 PM
Kathy Hidalgo's Avatar
Can I use a p28?
Civic_Rojas
Aug 4, 2013 05:04 AM
Vindicator9000
May 3, 2008 05:29 PM
ITR.#1446
Sep 9, 2005 10:16 PM
V8K1LLER
Jan 28, 2005 01:11 PM
jcivic
Jan 25, 2003 12:35 PM
