B18 swap 00 civic help
I recently bought a b18b1 from a 99 teg (obd2a) and am planning to put it in my 00 civic ex coupe (obd2b) and im not sure what to use regarding the harness and ecu i've heard keeping the d16 harness and using the p75 from the teg should work but there seems to be mixed Opinions. And if i do this will i need something to convert from obd2a to obd2b? All help is appreciated thanks
Re: B18 swap 00 civic help
Originally Posted by jspinelli8
(Post 51375242)
You must go obd1 if you plan to tune
Only way to tune Hondas on obd2 are k-series motors |
Originally Posted by theYBLEGAL
(Post 51375487)
(Post 51375583)
Thanks, so i should use the obd1 p75? And do i use the civic harness with an obd1 conversion?
Originally Posted by JRCivic1
(Post 51376217)
Yes, an OBD-1 P75 ECU with a tuning solution and a OBD-2B -> OBD-1 conversion harness makes it plug and play at the ECU end. You use the engine harness from the '00 EX coupe and modify it to fit the engine... changing clips/connectors and shortening/lengthening wiring as necessary.
(Post 51375244)
And if i was to want to be able to tune it would my only option be some kind of standalone ecu
