Temp gauge/ coolant issue
Old Jul 20, 2017 | 03:09 PM
Dm914's Avatar
Default Temp gauge/ coolant issue
I have a 96 civic gsr swap. So sometimes ill be driving around normally and the needle will be sitting normal (slightly below halfway) and then ill look back and the needle will slowly make its way to about 3/4 or a tad bit under 3/4 then go back to its normal position to slightly below halfway. It does that the whole time the car is being driven. The radiator level is fine so is the overflow, no leaks on the floor and there is no moisture where the block meets the head. Car never shuts off nor does it feel weak, when i do pop the hood you do smell a hint of coolant though, but no leaks. I ordered a new radiator cap but otherwise any idea what else it could be?
Old Jul 20, 2017 | 03:31 PM
da1lydr1ver's Avatar
Default Re: Temp gauge/ coolant issue
Make sure your coolant system is bled. It sounds like theres an air bubble in your system, causing your temp to spike sporadically.
Old Jul 21, 2017 | 07:40 AM
StayKrafty's Avatar
+1 on possible air in the coolant.
TOO MUCH TORQUE
Jul 28, 2010 09:21 PM
RG400SmartTowel
Aug 11, 2009 12:34 AM
corince06
Jun 11, 2008 12:48 PM
aeon
Jul 13, 2006 09:30 PM
Mario.
Mar 5, 2005 06:30 PM
