Stripped AC high port shrader valve
I was servicing the AC system and replaced the shrader valves inside both ports of the AC. But while installing the high port shrader valve; I tightened it too tight with the tool and broke the little metal pieces the tool uses to hold/grip onto the valve. So it seems pretty stuck in there; I do not really wish to deal with trying to remove it, because I've heard it is either really difficult or involves replacing the whole pipe/tube.
The system was vacuumed and no leaks detected and holds pressure.
Would it be okay to just leave it as is; and recharge the system?
Re: Stripped AC high port shrader valve
I guess you might as well since you've already pulled vacuum on it... Kinda past the point of no return now I think.
I think he means the little metal riser on the top-side of the valve core. you know, where the slot in the shrader valve tool fits onto... in which case, there shouldn't be any metal in the A/C system, but the next time that valve core needs to come out, he is boned.
I went ahead and charged the system and it seems to be holding pressure as well. I figure if the port ever does leak then I can consider replacing the whole pipe or adding one of these couplers as a different source of sealing?
integraboi1010
09-10-2008 03:15 PM
Draggin99Si
01-21-2006 09:13 PM
mdmitch2
06-23-2005 02:34 PM
