oil leak
Old Jun 24, 2017 | 08:56 AM
jald3rd's Avatar
Default oil leak
i have an oil leak(see attached picture), looks like its coming between the engine and transmission. is it an engine oil or transmission fluid? the oil leaking is kinda dark in color.
can anybody help me how to fix it. thanks
Old Jun 24, 2017 | 09:05 AM
BigPapaBear's Avatar
Default Re: oil leak
It looks like engine oil. You'll have the remove the transmission and put in a new rear main seal, but offset it, so it doesn't ride on the same spot on the crank (the old seal probably wore a groove in the crank).
Or you could try using an oil additive to renew the seal instead. Sometimes they do work, but that looks like a bad leak.
Old Jun 26, 2017 | 04:51 AM
jald3rd's Avatar
thanks for your input. i put bar's rear main seal repair, just letting the engine run for about 30 minutes for 2 days, leak reduces to tiny drop. will see, the product instruction said you can see best result after driving for 200 miles.
Old Jun 26, 2017 | 05:02 PM
civic402lx's Avatar
That is a band-aid fix. It may create more problem in the future then it is worth.
Old Jun 26, 2017 | 11:05 PM
civicdelsol33's Avatar
I've had this same problem and thought it was the rear main seal. Have you ever replaced the oil sending unit? That's where my leak was. It's right above the oil filter usually.
Old Jun 30, 2017 | 08:03 AM
jald3rd's Avatar
ok. i'll try to check more where the oil leak is coming out. i notice that leaked oil is too dark, i just did an oil change and the oil on the dip stick is clean and newer.
Old Jun 30, 2017 | 08:49 AM
mk378's Avatar
Look for stuff leaking above, like the distributor seal or VTEC solenoid.
The transmission fluid should be pale yellow, like new motor oil. In fact Honda says you can use motor oil in there.
bluemc
Mar 10, 2012 08:44 AM
einzelherz
May 27, 2011 03:45 PM
imtrill
Sep 29, 2006 03:35 PM
gill_za
16
Apr 24, 2006 01:46 PM
SKDRCR
Jul 2, 2004 02:27 PM
