My timing maps, and how much retard per psi on e85?
Old Jun 15, 2017 | 02:11 PM
2x0's Avatar
2x0
10 Year Member
Default My timing maps, and how much retard per psi on e85?
I am looking at the tune that was already done on the car before I bought it, and want to get some opinions on the timing maps. I know e85 can handle quite a bit of timing, but I just want a safe tune and I am used to starting with 1 degree retard per psi on my base maps. A/F ratio in boost is 11.5, 13 low vac and 14.7 high vac. I do plan on taking it back to a tuner, but I have other issues I need to sort out before that and I need to be able to drive the car for troubleshooting purposes.
B18C1 with forged internals, B16 ported head, GSR cams
FIC 1000cc injectors, Walbro 255lph, pump e85
GT3255e turbo
Stock ignition, NGK plugs gapped at .018-.020
FMIC
Here are the maps.
Thanks for looking
Old Jun 15, 2017 | 02:30 PM
DickensA's Avatar
Default Re: My timing maps, and how much retard per psi on e85?
Leave the timining alone and just adjust your fuel map
Old Jun 15, 2017 | 03:40 PM
turbociv910's Avatar
its a big jump from low cam to high cam
Old Jun 15, 2017 | 04:00 PM
2x0's Avatar
2x0
10 Year Member
Hmm, I hadn't noticed that. If my high cam cutover is around 5500 rpm, it looks like in most columns it advances timing by 2-3 degrees. Is that too much?
I can tune the fuel tables no problem, and I plan to. However I want to make sure the timing is detonation-proof as well.
Old Jun 15, 2017 | 04:13 PM
DickensA's Avatar
Your high cam shouldnt be starting at 500rpm either because itll never be there in reality
youre losing a lot of resolution having it set up like that
again leave timing alone and just get your afr in check
tune timing at the track or on a dyno
Old Jun 16, 2017 | 05:14 AM
2x0's Avatar
2x0
10 Year Member
Alright I will leave it alone, thanks for the advice!
I just wanted make sure, if I am going to tune my AFR's and take it up to 15psi for example.... if there is a general idea of how much total timing would be too much, or what a safe number would be.
Old Jun 17, 2017 | 05:51 AM
cruizinmax's Avatar
My car likes about .5 degree of retard per psi of boost but as everyone will say every setup is a little different. I have a 11.5:1 gsr with a gt2871r and itr cams. I got to my total timing by checking plugs and confirmed MBT on the dyno after.
Old Jun 17, 2017 | 05:54 AM
7rrivera7's Avatar
How does one learn to find MBT without formal training like taking an EFI101 course?
Old Jun 23, 2017 | 07:59 AM
Roy Leyva's Avatar
Those timing maps looks fine for 89-91 pump gas, i think you can advance a lot more on E85.
Old Jun 23, 2017 | 11:51 AM
2x0's Avatar
2x0
10 Year Member
Thanks for that input. It was supposed to be a very conservative map.
For street tuning, I will probably leave it alone. Perhaps on the dyno we will try to add some.
Old Jul 1, 2017 | 01:56 PM
Masterl1nk's Avatar
Looks pretty good to me, it is just a conservative timing map. Just take a look a bit on how are you retarding the ignition vs boost. On vtec table you have 1* or less between 11.9 and 15.8 psi, whereas almost 4 psi between them.
b.serious
Sep 22, 2008 07:02 AM
miro_gt
Sep 19, 2005 02:17 PM
dominate9
Dec 4, 2003 05:05 AM
wzcb08
May 19, 2003 07:47 PM
LudeSi-93
Jun 21, 2001 07:46 PM
