jdm b18c 11.1 on 93 pump gas
Old May 10, 2017 | 10:58 AM
eddie7978's Avatar
Default jdm b18c 11.1 on 93 pump gas
is it safe to run the jdm itr motor on the stock ecu with 11.1 on 93 pump gas ??
or would i need to get it tuned?
Old May 10, 2017 | 01:50 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: jdm b18c 11.1 on 93 pump gas
Yes it's safe
Old May 10, 2017 | 02:57 PM
eddie7978's Avatar
ok say i did want to get it tuned.. would that make it safer? how does that work?
Old May 10, 2017 | 07:56 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yes, it would be safer. The engine's performance would be optimized WITH the components in your car along with the environmental conditions in your area.
Old May 11, 2017 | 05:45 AM
Txdragon's Avatar
11.1? Are you referring to compression? This is a VERY vague question.
Even these old-as-**** ECUs are capable of compensating most N/A modification to a certain extent, on their own, without the need of our meddling; I.E. any tuning programs. Some cases, you'll just end up stripping your car of fuel economy and MAYBE being able to do justice to the mods you've installed. I have been working on my tune for about 2 months now and just about have it where I want it, but I have lost about 125 miles per tank of gas. I would say unless you're going boosted or some radical, ground-up N/A build, I wouldn't bother with a tune. I choose to do so to learn as I am piecing together a boost setup But unless learning is your interest, or you're just a glutton for punishment; you're setting yourself up for some MASSIVE unnecessary headaches.
Old May 11, 2017 | 02:22 PM
eddie7978's Avatar
yea i just don't want to detonate the motor i know its recommended higher octane because in japan i know they have higher
Old May 11, 2017 | 11:26 PM
80%downtime's Avatar
If you're referring to 11.1 AFR, that's richer than I'd like to see on a turbo car. On NA, you'd want to shoot for about 12.5. Go get it tuned if you're at those values. Yes, you can run the car. No, it won't be optimal. Yes, things will wear out faster.
If you're referring to 11:1 compression, I'd recommend getting a good pair of detcans and just running the car hard while listening for knock. Hear nothing, see nothing, say nothing is the general motto I follow. Additionally, the ECU itself will have some sort of ignition retard if you hit knock, which will compensate for it, but ideally, you want to get it dialed in so the ECU doesn't have to make huge compensations (most of them are only good for about 10% off of the values they're supposed to see).
Old May 12, 2017 | 02:27 AM
eddie7978's Avatar
i'm taking about compression .. if i get it dyno tuned would it be safer even if i use 93 octane?
Old May 14, 2017 | 06:20 PM
Ideally, you want to get it dyno tuned and then have that tune verified on street by driving it around to make sure there's no "problem areas". A dyno will get you number for number, but it won't exactly be a proper representation of real world conditions. If it is dyno tuned, (hopefully) your tuner will be listening for knock, so it shouldn't be an issue. If your tuner doesn't bother with that step, your ECU will still pull timing if it detects knock and a CEL will tell you that there's an issue and you tell your tuner. Make sure you have your tuner tune on the fuel type you will be using.
Old May 15, 2017 | 03:23 AM
eddie7978's Avatar
will a cel come on the jdm ecu if it detects knock or just usdm?
Slowp0ke
25
Sep 30, 2010 04:24 AM
fanta!
Jul 6, 2005 08:13 AM
ramz7887
May 23, 2004 10:25 PM
BLK99VTECR
Aug 24, 2003 01:10 AM
Flamenco-T
Sep 4, 2002 04:20 AM
