Jdm b18b in eg coupe, Idle problem NEED HELP!
Old Feb 24, 2017 | 04:31 PM
JDM4Banger's Avatar
Default Jdm b18b in eg coupe, Idle problem NEED HELP!
ok my issue is way different then any others. My idle isn't surging. It acts like it has two modes to the idle. When I start it up, it goes all the way to 4-5k rpm. After while its goes to the second mode. It drops down to the regular idle around 600-1500 anywhere between that. Normal idle. Then I go driving after awhile of driving it goes back up to the second mode. 3-4-5k rpm. And then drops back down. It does that over and overs up for 10-20 mins and then back down for 10-20 mins. Up and down. And it's very annoying and I don't wanna drive it with such high Rpms. Driving is fine it's goes down when I shift and drives fine just when it's in neutral the Rpms are so high. And sometimes it's normal. Again it has like two modes. I have no clue what's goin on and I've tried a lot. Extensive research and I still can't fix the problem. Can anyone help or suggest some ideas please. Thank you.
Old Feb 26, 2017 | 04:04 PM
m90polk1's Avatar
Default Re: Jdm b18b in eg coupe, Idle problem NEED HELP!
Check iacv or swap with know good one and make sure TPS voltage is within specified range.
Old Feb 26, 2017 | 05:29 PM
JDM4Banger's Avatar
I'll give that a try but do you understand what the problem is. It's werid. Sometimes is normal idle then outta no where it goes up to 4-5k rpm. And then after awhile it goes back to normal idle. It doesn't slowly go up to 4-5k it like goes up quick and stays there. It's not like slowly goes up and down it has like a set mode or somethin.
Old Feb 28, 2017 | 02:56 PM
m90polk1's Avatar
Could also try bleeding coolant, bubbles in the system can cause idle issues such as hunting idle randomly
ReactioN
Mar 24, 2008 05:22 AM
bb4 jdm lude
Mar 12, 2008 09:25 AM
EK Josh
29
Apr 11, 2005 11:05 AM
hybridracer504
12
Feb 8, 2005 05:25 PM
4doorB18Bcivic
Nov 17, 2002 03:56 PM
