93 civic hood stuck
Old Feb 22, 2017 | 02:33 PM
Carpoollane's Avatar
Default 93 civic hood stuck
So after a few weeks of driving the car I go to check the fluids, only to find it can't open the hood, the cable is pulling the latch, but it's just not opening, I've tried pulling on the cable to get more out but that didn't do any good, is there a way to get to the latch with the hood on or anything I can do to get it open other than cutting the thing
Old Feb 26, 2017 | 06:36 AM
Junior Blair's Avatar
Default Re: 93 civic hood stuck
hey man sorry im new here someone probably helped you already but what i did was sprayed wd 40 and let sit then had someone press down on hood while i pulled latch after a couple trys it worked
Old Feb 26, 2017 | 06:57 AM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Have someone help you. While you hold the hood release open, have them work the latch area to try and get it to pop. WD40 will break up the rust a bit but you'll need white lithium grease to lubricate the hinge. WD40 is NOT a lubricant (edit: not a lubricant you want to use on exposed piece for long term lubrication).
I've had this happen to me a ton.
Last edited by CX-Adam; Feb 28, 2017 at 01:12 PM. Reason: TC nit picking good information while, simultaneously, providing bad information.
Old Feb 28, 2017 | 01:13 PM
CX-Adam's Avatar
talks to himself
Community Builder
Pulled directly from the Honda FSM:
Lubricant Point: "Hood hinge and Hood Latch"
Lubricant: "White Lithium Grease"
Old Mar 1, 2017 | 01:23 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Originally Posted by CX-Adam
I'm saying I don't see you acting any better than I am.
I misinterpreted. My apologies.
I concede everything aka You are absolutely correct on almost every point.
Old Mar 1, 2017 | 01:35 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Have someone help you. While you hold the hood release open, have them work the latch area to try and get it to pop. WD40 will break up the rust a bit but you'll need white lithium grease to lubricate the hinge. WD40 is NOT a lubricant.
OP contrary to CX-Adam's approach and original comment. I WOULD use WD-40 for a duration.
A QUESTION OF LUBRICATION
Myth: WD-40® Multi-Use Product is not really a lubricant.
Fact: While the “W-D” in WD-40® stands for Water Displacement, WD-40® Multi-Use Product is a unique, special blend of lubricants. The product’s formulation also contains anti-corrosion agents and ingredients for penetration, water displacement and soil removal.
https://wd40.com/cool-stuff/myths-legends-fun-facts
After about a week or so and multiple exposures to WD-40 and the movement and action of the part appears to be restored and working efficiently. I would then switch to the lithium grease the factory service manual specifies. This is based on the purpose of WD-40 bolded above.
This should help clean up the part to be more susceptible to the long term lithium grease.
Old Mar 2, 2017 | 02:54 PM
Hey, sorry it took a little while, but I got it figured, the plastic stopper on the latch broke allowing the cable to pull into the latch instead of pulling the latch, so I did a little backwoods engineering to allow me to still use the hood release in the car to still open it properly, I do appreciate the input
Old Mar 2, 2017 | 02:59 PM
haggecha
Honda Civic (2006 - 2015)
Jan 11, 2019 04:23 AM
mbdm
Jan 20, 2011 02:32 PM
efjones9
Jan 11, 2009 01:04 PM
pimpwok
Dec 18, 2005 09:03 PM
Morning Call
Acura TL, RL & ZDX
Jun 12, 2004 10:40 AM
