mods to run nos in a gsr
Old Nov 9, 2002 | 10:53 AM
GSRacer1's Avatar
Default mods to run nos in a gsr
i have a gsr with 100000 miles on it and i am thinking about shooting dry nos kit in it
what kind of mods should i consider to run safely
Old Nov 9, 2002 | 11:30 AM
NCSTIdriver's Avatar
Default Re: mods to run nos in a gsr (GSRacer1)
MSD Ignition, 1 Step colder NGK spark plugs, Spark plug wires. Also an aftermarket intake, header, and exhaust will help to increase performance. This should be good for a 65-70 shot no problem.
Old Nov 10, 2002 | 10:06 AM
turbo5.7L's Avatar
Are you ****** stupid.. buy a wet shot.
Old Nov 10, 2002 | 10:57 AM
garados's Avatar
Default Re: mods to run nos in a gsr (turbo5.7L)
Let's try to be constructive. Why should GSRacer1 not get a dry kit? A good reason would be appreciated.
Old Nov 10, 2002 | 11:00 AM
AWDxBOOST's Avatar
yea...and dont say nos
Old Nov 11, 2002 | 02:31 PM
RockDawg_GSR's Avatar
Default Re: mods to run nos in a gsr (ls_teg)
I was thinking of getting a "DRY" kit. Why should i get a "WET" kit....Isnt a Dry kit more reliable.What shuold i get if i were to just want a little more power to get some momentum going...I dont want that much more power from the Nitrous i just wanted a little more help. I have basic mods just wondered what else i would need.
Old Nov 11, 2002 | 02:34 PM
Default Re: mods to run nos in a gsr (RockDawg_GSR)
Dry kits are cheaper and easier to install. Wet kits properly mix your air and fuel into your cylinders which allows you to run a higher and safer shot. Although it costs more.
Old Nov 11, 2002 | 02:56 PM
OBDI JEDI's Avatar
Default Re: mods to run nos in a gsr (NCH22driver)
with 100K on ur odometer, id be more worried about your rings, and timing belt, aside from whether you get a wet or dry kit. Unless these have been recently changed. Dont forget a clutch, and a conservative nitrous user
Old Nov 12, 2002 | 10:40 AM
mskibbz-T's Avatar
Default Re: mods to run nos in a gsr (OBDI JEDI)
Dude just get a ZEX kit, 2 steps colder plugs, and run up to a 75 shot... Retard your timing 2 degrees for a 65 shot and 4 degrees for a 75 shot... You'll be fine and you can get it all for under $600 installed including filling your bottle...
Old Nov 12, 2002 | 11:27 AM
GSRdriver's Avatar
Default Re: mods to run nos in a gsr (mskibbz)
Buy my GSR NOS PLATE SYSTEM...thats what you should do if you want to run a wet shot. It a direct port and goes right in the middle of you IM. Its never been used and still in the box.. 500 Shipped. I'll even throw in the NGK's I bought.
I haven't really heard people's opinions about a dry set up. But w/ 100k, I'd be concerned about rings, pistons, and the condition of your motor.
Old Nov 12, 2002 | 12:18 PM
PM-Performance's Avatar
Default Re: mods to run nos in a gsr (GSRdriver)
actually from someone who has had every kit on their car. . . . the NOS dry kit was harder to instal l that the single fogger wet kit . and the direct port is the hardest only becuase of having to tap the manifold.
Old Nov 12, 2002 | 01:16 PM
spoonee's Avatar
Default Re: mods to run nos in a gsr (itr206)
nos...
Old Nov 13, 2002 | 12:13 AM
Default Re: mods to run nos in a gsr (spoonee)
I think my motor is in pretty good conditoin. I basically had all the head work done recently. Yes and i would chek my pistons and rings out..But i was really wondering what kit would be less crucial on the motor. I would also be looking for only like a 50 shot or something.i can do all the install or some1 i know if its 2 complicated for me, but im pretty sure i could do it, so money for install isnt a problem.So then what would be cheaper and what benefits would i get from either kit more than the other?
Old Nov 13, 2002 | 02:35 AM
97hb's Avatar
No a wet shot puts it right into the intake pipe where fuel can puddle and cause a intake backfire. A direct port is much safer than a wet shot. A dry kit is safer than a wet shot. I know of a couple of people running wet shot and never had an intake backfire, but you never know.
Old Nov 13, 2002 | 05:32 AM
Default Re: mods to run nos in a gsr (97hb)
i never had that problem .
btw look at my sig, im selling my direct port kit.
Old Nov 13, 2002 | 09:21 AM
stupidfast's Avatar
Ive had nitrous express fogger kit on three different cars now and never a problem. Went through roughly 30 bottles on my stock gsr motor with i/h/e and stock timing.. 75 shot.. Car ran great with stock plugs and all.. I was running 13.6 with this setup.. But its all about how you use it.. Any nitrous kit will make your car faster, its up to you not to abuse it and blow your car up.. Foggers work great for anything under 100 shot. As long as you are injecting the nitrous as far down your intake tube as possible. It allows the nitrous and fuel time to atomize and equally divide between the cylinders..I would agree that direct port is safer, but way harder to install and more money. You can be safe with fogger.
Ps Dry sucks ***!!!
Old Nov 13, 2002 | 01:34 PM
NA-GSR's Avatar
You also need the latest copy of F&F....
Old Nov 14, 2002 | 02:22 PM
JDiMageDC2's Avatar
Default Re: mods to run nos in a gsr (NA-GSR)
First of all do a leakdown and compression test. Go witha wet setup. Reliability is the reason. It combines the proper amount of fuel and N20 rather than just spraying N20 in the intake and hoping it mixes proportionally. If you want real consistency go direct port. I wouldnt run more than a 75 shot unless you sleeve the block, considering the mileage you have and stock internals.Like these guys said, upgrade the ignition, plugs, and fuel pump and you'll be fine. Tuning is the key, and ya gotta keep the plugs checked. A window switch is a great investment as well, it can prevent you from spraying in an overrev if say you miss a shift. Good luck with the bottlefeeding.And oh yeah, you'll need to upgrade the clutch.
[Modified by GSRTUNR, 11:25 PM 11/14/2002]
[Modified by GSRTUNR, 11:30 PM 11/14/2002]
dustywebber
Jul 9, 2004 06:04 AM
f22suzuka
Jul 27, 2003 09:59 AM
STEV3-O
May 19, 2003 08:12 AM
PROJECThX
Apr 27, 2002 05:45 AM
hybrid_eg
Jul 16, 2001 10:46 PM
