Window switch problem HELP !
Old Dec 4, 2016 | 09:30 AM
Chrisxnj's Avatar
Default Window switch problem HELP !
Hello I'm new to the forum , I have a 1997 Honda Civic lx
I'm having issues with my passenger window ,
from the drivers door switch the passenger window does not go down or up . But the drivers does
from the passenger switch the window only goes down does not go up ..
what can it be?
Old Dec 4, 2016 | 10:02 AM
Former User's Avatar
Default Re: Window switch problem HELP !
Check the fuse for the passenger window.
Old Dec 4, 2016 | 11:53 AM
Chrisxnj's Avatar
may be dumb question but where? I've checked fuses under the dash already
also the pass window goes DOWN but will not go back up unless i jump the cables
Old Dec 4, 2016 | 12:18 PM
Check for broken wires the door jamb connectors.
Old Dec 4, 2016 | 12:28 PM
Chrisxnj's Avatar
i will try once gets warmer , I'm in nj getting dark now and chilly
Old Dec 4, 2016 | 01:30 PM
civic402lx's Avatar
You have broken wires in the door jam connectors. Be prepare to depin and solder. Or visit the junk yard for replacement harness plug.
when I bought my 98 lx only driver Window work. Lots of broken wires.. Had to take the door off to fix the wires.
Old Dec 4, 2016 | 04:54 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Known broken wire issue and crap design by Honda, frankly.
Old Dec 4, 2016 | 07:36 PM
civic402lx's Avatar
Exactly. There were little to no wiggle room for the harness. Overtime it just fail. I had to replace both front door harness with a pair of unbroken I found from junkyard. The extra length help..
Old Dec 5, 2016 | 07:46 AM
Chrisxnj's Avatar
Will check thanks guys
Old Dec 5, 2016 | 07:47 AM
Chrisxnj's Avatar
Am I able to order those pieces online
Old Dec 6, 2016 | 01:21 PM
fcm's Avatar
fcm
Old Fart
Yes, but not cheap, [$80-$100]best bet is your local bone yard, [PicknPull, under $15] lots of Civics at PicknPull.
You can also repair the door jamb wiring, also with PicknPull parts, find the undamaged leads you need, de-pin at the A pillar plug- and cut lead inside the door, no need to remove door, just unplug harness at A pillar, remove door panel and front door speaker, pull harness into door and out the speaker opening, remove wires needed, [I will take the whole plug and cut the leads inside the door] that way when I make the repair the connection, [solder and shrink tube] will be inside the door and not in the boot, I have done this more then a few times when a good harness was not available, you do not even need the same color leads, [the pins will be the same] just do them one at a time if you are replacing more then one lead. 94
Joey Mitchell
Oct 18, 2018 04:59 AM
eg6sir88
Mar 24, 2010 06:25 PM
sjbmx
Aug 9, 2009 05:38 AM
XLR8_HFX
Feb 9, 2008 05:07 PM
Erik95LS
Dec 19, 2001 06:39 PM
