1998 Civic D16y8 transmission stuck in gear
Old Nov 24, 2016 | 07:08 PM
vtecftw562's Avatar
Icon5 1998 Civic D16y8 transmission stuck in gear
I was hoping someone could help us out with this problem that happened today.
98 Civic EX with D16y8 is stuck in gear even when it's in neutral. If he tries taking his foot off the clutch, the car yanks forward.
When he puts it in gear and tries to move, nothing happens. It won't reverse or go forward. But when its in neutral it wants to move forward like its in gear. He tried holding the clutch down and moving through the gears - it was kinda hard to put in 1st gear and it wouldn't go in 2nd unless he forced it. It went through the other ones fine. We had to push the car inside after that because it was time to eat turkey. Happy Thanksgiving
Old Nov 25, 2016 | 11:02 AM
mk378's Avatar
Default Re: 1998 Civic D16y8 transmission stuck in gear
The bushings in the shift linkage could be bad. So when you move the shift handle it's not actually moving the rod on the transmission where it should go. You should be able to reach under the car and pull the rod at the transmission out to the middle position, that would be neutral.
conner987
Apr 30, 2012 02:59 PM
.paul
Jan 12, 2007 12:35 PM
jtchinoy
Dec 28, 2006 01:33 PM
JDMGSR-T
Oct 27, 2006 02:48 PM
jl110ex
11
Sep 21, 2004 07:35 AM
