Failed smog today In CA, Gross Polluter, Help!!!
Old Nov 12, 2016 | 07:04 PM
Timexlord's Avatar
Default Failed smog today In CA, Gross Polluter, Help!!!
Took my 1997 civic ex (150,xxx miles) AT, today to get smogged and it failed, Gross polluter, spoke to the guy testing it and he said I had the wrong air filter??? Also said (vacuum lines to sensor disconnected) I didn't see anything disconnected. Any help would be great guys thanks.
Old Nov 12, 2016 | 07:49 PM
Former User's Avatar
Default Re: Failed smog today In CA, Gross Polluter, Help!!!
Swapped engine and ECU?
CEL codes?
Old Nov 12, 2016 | 07:56 PM
Timexlord's Avatar
D16y8 motor. Everything else is stock other then a magnaflow exhaust, still have the cat
Old Nov 12, 2016 | 07:57 PM
Timexlord's Avatar
Also it's not throwing any codes
Old Nov 13, 2016 | 03:12 AM
mk378's Avatar
You have a two-stage VTEC head, that is not stock. Note the non-stock wires running from the VTEC solenoid to somewhere under the battery.
The NO is the only one at GP level but HC and CO are also well over the max. Failing all 3 pollutants at the same time but running OK usually means the cat is dead.
Old Nov 13, 2016 | 06:25 AM
Post the head, block, and ECU codes.
https://honda-tech.com/forums/honda-.../#post48684945
Does the CEL work?
https://honda-tech.com/forums/honda-...lists-1901557/
High O2 levels also suggest an exhaust leak that is contributing to the high HC levels.
Old Nov 13, 2016 | 07:40 AM
Timexlord's Avatar
So from the looks of it, I have an exhaust leak and need a new cat? What would be the disconnected sensor stated on the list? Also thanks for your guys advice
Old Nov 13, 2016 | 11:07 AM
Timexlord's Avatar
Old Nov 14, 2016 | 04:24 AM
mk378's Avatar
That is not the stock block either. Has this car ever passed CA smog check in its present configuration?
Old Nov 14, 2016 | 06:34 AM
Timexlord's Avatar
I just bought the car, from someone, it was no op, obviously I know why now, but it was last registered 2014 so I'm assuming it did.
Old Nov 14, 2016 | 06:40 AM
Unwise purchase.
What ECU is running the engine?
Old Nov 14, 2016 | 07:25 AM
tony_2018's Avatar
Fish Twig
Thats not a d16y8, not sure how you got that..
I see the previous owner ran a wire to engage the 16 valve so that shouldn't be a problem. Did you ask the guy what vacuum lines he was referring to?
Old Nov 14, 2016 | 09:07 AM
Timexlord's Avatar
The smog guys response was "see your mechanic". I figured it was smithing I could find after he was no help, I'm taking it to a mechanic today to check it out
Old Nov 14, 2016 | 09:23 AM
tony_2018's Avatar
Fish Twig
Is your idle high? The dumbass didn't even specify what air intake was wrong. Was he talking about the intake manifold or the intake air filter box.
Old Nov 14, 2016 | 09:25 AM
tony_2018's Avatar
Fish Twig
Is your car an HX or an EX? I'm trying to wrap my head around why he would say your EGR was DISCONNECTED.
Old Nov 14, 2016 | 09:32 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
In CA the seller has the legal obligation to provide a valid smog test at the time of purchase.
Take that for what you will.
Old Nov 14, 2016 | 09:38 AM
tony_2018's Avatar
Fish Twig
Lift this cover up and take a picture.
Old Nov 14, 2016 | 12:29 PM
Timexlord's Avatar
@tony it's a ex model, and I believe the "disconnected" is referring to the vacuum line. Also the car is now at my mechanic so I cannot post pictures of it till I get it back
Old Dec 2, 2016 | 12:58 PM
Timexlord's Avatar
UPDATE**** so I took it to my mechanic and and his diagnostic was that the cat was the original one so he had a muffler shop install a new one, he also tucked those loose wires away. Smogged it again and passed with flying colors. Thanks for everyone's input and opinions.
Vertex Spirit
Aug 29, 2008 09:19 PM
95ex5speed
Oct 20, 2004 12:17 PM
built562
May 4, 2004 11:47 PM
