HELP! car wont pass CA smog at BAR
not sure why car is not passing smog, no modifications everything is stock, possibly bad cat or 02 sensors??? what do you guys think? car has CEL on (system too lean/rich). already changed spark plugs, cap, rotor, wires. already tried resetting ECU, CEL just comes back; also never messed with timing. thanks for any input!
2000 civic EX - obd2 sucks...
15 mph
HC - 273 (max = 64)
CO - 9.99 (max = 0.55)
NO - 10 (max = 477)
25 mph
HC - 297 (max = 47)
CO - 10.2 (max = 0.54)
NO - 12 (max = 764)
15 mph
HC - 273 (max = 64)
NO - 10 (max = 477)
25 mph
HC - 297 (max = 47)
NO - 12 (max = 764)
Re: HELP! car wont pass CA smog at BAR (Vertex Spirit)
if everythings stock, why'd you have to go to the ref? try checking what your CEL is for. dont guess and throw money at the problem. HC's usually cat/o2 sensor problem.
Wow, it looks like your running on the rich side buddy. I would look more into the CEL, it will most likely be your cause. Once you get the CO to drop the HC should do the same.
oh i had to go to the ref for the expletive altered emissions /smog. got pulled over and was running a turbo setup, had the greddy carb sticker posted but nothing directly on the charge pipe = automatic ticket....
Thanks for the replies, any other thoughts? gonna get a major service done to see what happens
* B A N N E D *
Re: HELP! car wont pass CA smog at BAR (lek9l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lek9l »</TD></TR><TR><TD CLASS="quote">Good luck, no refs, return motor to stock.</TD></TR></TABLE>
did you even see when this post was created almost 2 years ago pay attention dumb ***
Re: HELP! car wont pass CA smog at BAR (twinksack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twinksack »</TD></TR><TR><TD CLASS="quote">
did you even see when this post was created almost 2 years ago pay attention dumb *** </TD></TR></TABLE>
lol he got pwnd
lol he got pwnd
boots420
37
05-18-2007 03:35 PM
