Help:Retarding Dizzy cap
Old Nov 8, 2002 | 12:53 PM
IamVtec's Avatar
Default Help:Retarding Dizzy cap
i retarded my dizzy just about half pass of where it use to be. Will it be alright to leave it like that? or will it mess anything up? i retarded it because someone told me it would help my NOx on my emissions testing. should i set it back to where it's suppose to be after im done? with the emissions, or can leave it ? thanks
Old Nov 8, 2002 | 01:22 PM
MADEINIRAQ's Avatar
Default Re: Help:Retarding Dizzy cap (crx dragga)
buy a timing light and a helm manual
Old Nov 8, 2002 | 03:55 PM
Malgerus's Avatar
yeah, buy a timing light. Did you at least make a mark before you messed with it, so that you can set it back to where it was before?
BTW, I don't think retarding the dizzy will help your emissions. I did hear that advancing it does.
Old Nov 8, 2002 | 05:13 PM
ThatRicerDaniel's Avatar
Default Re: Help:Retarding Dizzy cap (Mr. S)
you dont gotta buy a timing light .. espically if your not tryin to be precise.. just let the car run at idle after its warm .. then play with the dizzy and you can hear the idlle go up and down ..as you retard the idle will go down.
Old Nov 9, 2002 | 08:46 AM
racerxadam's Avatar
Default Re: Help:Retarding Dizzy cap (NitrousDreamz)
please keep misguided advice to yourself. the way that you mentioned he adjust his timing could be very detrimental to his motor. in other words ka-boom.
Old Nov 9, 2002 | 02:07 PM
sporkcrx's Avatar
Default Re: Help:Retarding Dizzy cap (racerxadam)
my motor has been fully advanced, and fully retarded, and it has ran fine. no kabooms here.
Old Nov 9, 2002 | 04:37 PM
Aphrodavid's Avatar
the only time ive ever heard of someones motor blowing because of timing is when they were running N2O.
retarding your timing does help with emissions in some cases. mainly for the reason that when you retard your timing, your idle goes lower, thus helping you pass the idle test, as far as load tests, the same principal applies, even though the car will run like crap and probably not start up again if it dies, until you reset the timing.
Old Nov 9, 2002 | 07:01 PM
misguided? motor goin kaboom because of retarded timing? thats the lamest thing i ever heard.
Old Nov 14, 2002 | 06:41 PM
racerxadam's Avatar
you said:
if your not trying to be precise, then play with the dizzy and you can hear the idlle go up and down ..as you retard the idle will go down.
so you should set the timing based on the idle? how do you know what idle speed produces what timing? Have you ever driven up a hill at low rpm's and high load in a car that had the timing advanced too far? It goes *ping* *ping* *ping*. That is the sound of detonation and also the sound of a broken engine if its not caught in time. BTW ka-boom is a dramatic way of saying this is a bad ******* idea.
[Modified by racerxadam, 11:04 PM 11/14/2002]
Old Nov 14, 2002 | 07:02 PM
[QUOTE].. espically if your not tryin to be precise.. QUOTE]
if you gonna try to quote me dont do it half ***.
Old Nov 14, 2002 | 07:06 PM
racerxadam's Avatar
there happy. but the fact remains that timing happens to be something that should be precise. we're not talking a range of 0-100 its more like 12-18 degrees and one degree can make a huge difference. setting the timing by listening to the idle is still misguided information.
doubleoazn03
May 6, 2011 10:29 AM
hannslebo
Jul 26, 2009 02:35 PM
polishedturd
May 8, 2008 06:51 PM
casmall08@yahoo.com
Jun 12, 2007 06:14 PM
Civic89
Aug 8, 2002 01:48 PM
