timing light
Old May 8, 2008 | 12:44 PM
polishedturd's Avatar
I like PIE
Default timing light
i just went and checked my ignition timing with my cheap timing light from oriellys just now and noticed that with the clamp that goes around the #1 plug positioned wiith the arrow towards the motor my timing mark shows up sparaticly and with the connector positioned towards the dizzy the timing mark is right on. is this a problem?
my car idles fine and everything but im a perfectionist and i want it to be perfect.
Old May 8, 2008 | 01:30 PM
hatchling37's Avatar
Default Re: timing light (polishedturd)
Yes. It's possible the ECU is trying to compensate for your bad timing, so it's still able to idle properly. Check it with a good light and compare your results.
Old May 8, 2008 | 06:51 PM
I like PIE
Default Re: timing light (hatchling37)
thanks. anyone else?
i have been told by others that its ok.
rhdins
Aug 25, 2008 07:26 PM
xJDMCx
Sep 15, 2006 09:34 AM
DieMaster
Jul 2, 2004 09:09 AM
Magick211
Dec 11, 2001 04:29 PM
Jimmy L
Aug 21, 2001 01:14 PM
