B16a2 compression test
Old Oct 10, 2016 | 07:45 PM
Type 56's Avatar
Default B16a2 compression test
Here are the result of my compression i did earlier tonight:
1st Compression Test without oil
C1 160
C2 150
C3 150
C4 159
2nd Compression Test w/oil
C1 175
C2 165
C3 160
C4 160
Are the numbers any good?
Old Oct 11, 2016 | 04:01 AM
Tachi's Avatar
Default Re: B16a2 compression test
Hot engine? As in coolant gauge firmly in the middle and the car driven around a bit?
The H22A in my Accord right now pulled an even 155psi hot, no oil a month and a half ago. She still runs like a banshee but you will smell the oil burning, though that might be my valve seals. That's getting awfully close to the rebuild point, at least for your engine there, rings are cheap and you can hone the bore yourself.
Old Oct 11, 2016 | 10:14 AM
Type 56's Avatar
Nah. I tested it while the engine was cold.
Did another compression test, this time while the engine was still warm. And here are the results:
Hot Test
C1 180
C2 175
C3 172
C4 178
C1 215
C2 220
C3 195
C4 200
Old Oct 11, 2016 | 01:37 PM
fcm's Avatar
fcm
Old Fart
All within 10% so good, C3 compression ring(s) are tired but still working.
Are you having a problem? 94
Old Oct 11, 2016 | 03:17 PM
Type 56's Avatar
No, no problems at all. No CEL. Everything is running in good condition. Thanks for the input!
Old Oct 12, 2016 | 11:10 AM
fcm's Avatar
fcm
Old Fart
There is a saying "if t ain;t broke don't fix it" 94
vinuneuro
Apr 25, 2007 10:13 AM
Brad
Sep 8, 2006 02:13 PM
Azcheron
Jun 23, 2005 09:34 PM
crx1856
Oct 11, 2003 11:11 AM
