compression test questions and results
Old Oct 11, 2003 | 10:52 AM
crx1856's Avatar
Default compression test questions and results
i did a comp test yesterday when the car had been sitting for about and hour and a half so it wasn't at operating temp. i got varying results. 182,190,200,195. i put some oil in the cylinders to see if the comp raised and they did. today, i did a comp test at operating temp and my numbers were almost 200 across the board. i drove it about 10-20 miles since adding the oil. do you think my numbers were wrong the first time being that it wasn't at operating temp or do you guys think i still have oil in the cylinders making me think my numbers are ok.
Old Oct 11, 2003 | 10:54 AM
SKDRCR's Avatar
Default Re: compression test questions and results (crx1856)
the oil should have burned off by 10 miles
Old Oct 11, 2003 | 11:11 AM
GaRn's Avatar
Default Re: compression test questions and results (SKDRCR)
the oil was probably gone within a few seconds of the engine running.. your supposed to measure compression when the engine is warm i believe..
Type 56
Oct 12, 2016 11:10 AM
jdmwarrior
13
Jan 30, 2013 08:30 PM
98exowner
Sep 9, 2008 12:15 PM
Fat Chick Magnet
Nov 22, 2006 09:52 PM
osuPrelude
Nov 4, 2002 08:53 PM
